Replacing TC -I'd appreciate some tips - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 10-24-2017, 07:25 PM Thread Starter
Torquedup's Avatar
Garage
Howdy all,
I recently ordered a Revmax low stall torque converter to replace my old one which I toasted pretty well–thankfully no metal shavings in pan (except a tiny bit of brass but not enough to worry about).
What's gonna be my process for replacing the Torque Converter?
And can I reuse the tc-flexplate bolts?
Thanks!
2009 F250 King Ranch 6.4L CCSB
Spartan 275 hp tune
DPF-Delete
EGR-Delete
S&B Intake
Leveling Kit
2 10"inch subs
800 watt amp
Torquedup is offline
post #2 of 3 (permalink) Old 10-24-2017, 07:38 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Replacing TC -I'd appreciate some tips
When installing the converter stand the trans on end. Put the converter on the shaft and spin it. It needs to drop in far enough that it is inside the front of the bellhousing. Don't reuse the flexplate nuts.
Mark
Mark Kovalsky is offline
post #3 of 3 (permalink) Old 10-24-2017, 09:19 PM
Administrator
Zmann's Avatar
agreed get new bolts
and I can't reiterate enough to make sure the TC stays seated if it sneaks forward and you bolt it altogether bad things/will can happen
and if doing this yourself get a remote start switch so you can bump over to the next bolt
DTR's Donation page
RIP DTR Ron
Zmann is offline
