Newby!! Tranny Question?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 02-23-2010, 11:04 PM Thread Starter
hendricksbus's Avatar
I just bought a 96 F-250 with 139K! I'd like too keep it for as long as possible! the truck will be use for manly wood haul'n and pulling my 13' flat bed trailer! My question is whats better,best for a dollar too do! Shift kit, trans command, TC, pressure lock module, exchange accumulator or adding a magnfilter to the return line after the cooler?? Thanks for any opinion!!
1996 F-250,Ext.cab,LB,4x4
stock tires
180K,6 pos chip,Open air filter, 3'' down pipe,fpr mod,ccv mod
4.10s gears!
Boost, Pryo and transmission gauges
sonnax shift improver kit
bronco tank mod
hayden cooler for transmission
hendricksbus is offline
post #2 of 10 (permalink) Old 02-23-2010, 11:50 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Newby!! Tranny Question??
In my opinion the best thing to do is change all of the fluid every 30,000 miles and keep it from getting over 220įF.
Mark Kovalsky is offline
post #3 of 10 (permalink) Old 02-24-2010, 01:45 AM
Offical Puddle Displacer
pstroke96's Avatar
Send a message via AIM to pstroke96
proper up keep is the best way to make your trans last
Refugee
pstroke96 is offline
post #4 of 10 (permalink) Old 02-24-2010, 02:32 AM
foo show.
Ltr 450 is offline
post #5 of 10 (permalink) Old 02-24-2010, 06:45 PM
Don't use anything like a trans command, you could use a shift kit but a better option is a BTS VB set up for your usage. A 6.0 converter is a option. Get the biggest cooler you can fit and like others said filter and fluid every 30k.
email:
Website:
OBSWIZ is offline
post #6 of 10 (permalink) Old 02-24-2010, 08:51 PM Thread Starter
OK! a 6.0 converter will slid right in my e4od?? just a simple swap!!! I've heard and been told that you want firm quick shifts with this tranny! not the prolonged ones in the stock form! and that the long soft shifts are causing accelerated wear! is the fact or fiction!! thanks!
stock tires
4.10s gears!
bronco tank mod
post #7 of 10 (permalink) Old 02-24-2010, 10:15 PM
aklim's Avatar
Call Brian's Truck Shop and get a Valve Body. Ask him about tuning the trans for the VB to get the max out of it.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #8 of 10 (permalink) Old 02-25-2010, 01:02 AM Thread Starter
Where is Brains shop?? Im in wisconsin!!
stock tires
4.10s gears!
bronco tank mod
post #9 of 10 (permalink) Old 02-25-2010, 02:55 AM
aklim's Avatar
http://www.biranstruckshop.com
I'm in WI too. Big deal. They can ship it here and have your local garage R&R the VB
aklim is offline
post #10 of 10 (permalink) Old 02-25-2010, 03:24 PM
Buy a inch pound Tq wrench and change the VB yourself...then you know its done right.
6.0 Tq converter will "slip" right in. We have them..PM for prices.
email:
Website:
OBSWIZ is offline
