The ZF5 comparison thread - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 02-20-2010, 10:23 PM Thread Starter
So I have a dead E4OD in my truck and have been planning on swapping to ZF5 for some time. Now that my hand is forced, it's moving forward.
I bought a ZF S5-42 from a junkyard over ebay for $350. It's an 88 model, and has the typical cracked / broken case. I figured i'd weld the case up, but it's too far gone.
So I got a S5-47 front case over at pirate. Figured I'd detail some of the differences in cases here for anyone caught in my position who has to mix/match cases in future.
The extension housing had a big crack around the upper 3/4 of the output shaft / flange. We welded it up at work, my buddy did a great job.
The two individual gear stacks fit the case fine. Need to reset preload, but there's no significant length changes from 42 to 47.
The shift selector shaft is different from 42 to 47. The pocket depths have changed from 42 to 47, this will require either cutting down the 42 shaft or getting a 47 shaft.
There's some ribbing changes from the 42 to the 47. The case around the shift tower moved up on the 47, which should increase the torque capability some.
The input shaft retainer is different on the two cases. The 42 has a press in retainer from the inside, the 47 is a 3-bolt affair. Lengths appear same.
The gearsets are different from 42 to 47, different ratios. Allegedly, the 42 has a nicer ratio set for towing. We'll see.
Drain plugs are different 42 to 47.
(I'll put the photos up as soon as I can get them downloaded.)
Anyone want to contribute more photos and measurements to complete this thread?
1997 F350 CCLB Dually XLT
1986 Bronco 6.9 Turbo XLT
Powertrain engineer by trade have worked for three OEM's.
86turbodsl is offline
post #2 of 12 (permalink) Old 02-21-2010, 12:34 AM Thread Starter
Re: The ZF5 comparison thread
Ok, since I can't edit my post, I'll add some photos here.
Side by side, they look almost identical, but there's some subtle differences
the S5-47 insides
The S5-42 insides
The Cases are ribbed a bit different:
47 here, softer radiuses keeps stress less localized
While the 42 has some sharper areas
Shifter rail towers
Shifter areas - 47 has different detent mounts
The 42 has pipe plugs, the 47 has cup plugs
The 42 case with the selector rail bottomed.
The 47 case with the 42 selector rail bottomed. About a 1/4-1/2 inch shallower
The 42 front retainer is pressed in from the inside, difficult to change seals.
The 47 has a bolt in front bearing retainer, allowing easy seal changes.
The extension housing had cracks, one of my buddies welded up the cracks and tried to reinforce it.
If anyone has more photos of the different 47 parts, add them and let's make this a good resource for guys to save a couple of bucks.
I can post photos of the gears once I start the rebuild.
post #3 of 12 (permalink) Old 02-21-2010, 12:50 AM
2010 BOB Points Runner up
Dieselfever's Avatar
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
Very good information, Good to know!
-Michael
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
Dieselfever is offline
post #4 of 12 (permalink) Old 02-21-2010, 02:37 AM
OverFuelingForYourPlesure
pontiacross's Avatar
great info I'm sure I;ll be in the market for another one at some point
were there only 2 differant diesel zf5's, or are there more?
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
post #5 of 12 (permalink) Old 02-21-2010, 01:42 PM Thread Starter
Only two that I'm aware of. Two gearsets, both close ratio, but different:
S5-42 4x4, ZF
ZF S5-42 – 5 speed manual transmission has an aluminum alloy main gear case and tail housing with the bell housing integral to the case.
The ZF S5-42 is built in both a 2 wheel drive and 4 wheel drive version with gas and diesel designs
ZF first introduced the S5-42 in 1987 and was used in the Ford F250, F350, F450 and Super Duty trucks until 1994.
All gears on the S5-42 are fully synchronized with an input torque rating of 420 ft-lb
Standard gear ratios on the ZF S5-42:
Close Ratio
1st Gear: 4.14
2nd Gear: 2.37
3rd Gear: 1.42
4th Gear: 1.00
5th Gear: 0.77
Rev Gear: 3.79
Wide Ratio
1st Gear: 5.72
2nd Gear: 2.94
3rd Gear: 1.61
4th Gear: 1.00
5th Gear: 0.76
Rev Gear: 5.24
The ZF S5-42 main case cast number is “1307”
S5-47 4x4, ZF
ZF S5-47 – 5 speed manual transmission has an aluminum alloy main gear case and tail housing with the bell housing integral to the case.
The ZF S5-47 is built in both a 2 wheel drive and 4 wheel drive version with gas and diesel designs
ZF introduced the S5-47 in 1995 and was used in the Ford F250, F350, F450 and Super Duty trucks.
All gears on the S5-47 are fully synchronized with an input torque rating of 470 ft-lb
Standard gear ratios on the ZF S5-47:
Close Ratio - 7.3L Diesel
1st Gear: 5.08
2nd Gear: 2.60
3rd Gear: 1.53
4th Gear: 1.00
5th Gear: 0.77
Rev Gear: 4.66
Wide Ratio
1st Gear: 5.72
2nd Gear: 2.94
3rd Gear: 1.61
4th Gear: 1.00
5th Gear: 0.76
Rev Gear: 5.24
The ZF S5-47 main case cast number is “1317”
post #6 of 12 (permalink) Old 03-20-2010, 02:27 PM Thread Starter
Well, looks like I probably won't have to mess with this right now. I just picked up another ZF5 for $300 locally.
post #7 of 12 (permalink) Old 12-28-2011, 03:27 AM
I have a question, I'm going to buy a 95 f250 4x4 with the zf5, the back part of the housing broke right in front of where the transfercase bolts on, is it possible to get just that part and replace it? I can get this truck for dirt cheap
bigross is offline
post #8 of 12 (permalink) Old 12-28-2011, 12:14 PM Thread Starter
Yes, you can, but you might need to re-shim the gear stacks. That part is quite expensive. Do you have both parts still that you can get them welded back together?
That brings up another point. I think the ZF5 design is weak in that area. Even light aluminum and magnesium transfer cases seem to stress it. I think a large brace from tranny to transfer would be helpful in all but the mildest of applications. I'm working on a NP205 / ZF5 swap, I'll have to add my design to the site when I'm done.
post #9 of 12 (permalink) Old 12-28-2011, 02:39 PM
STILL LEARNING
Bradbilt's Avatar
Supposedly the F-superduty trans' were equipped w the Gasser gear ratio. But neither if mine did(96 or 88)
Bradbilt is offline
post #10 of 12 (permalink) Old 12-29-2011, 12:48 AM
Yea its still bolted to the transfercase. Will it be any weaker being welded?
bigross is offline
  LinkBacks (?)
LinkBack to this Thread: https://www.powerstrokenation.com/forums/26-transmission-related/53313-zf5-comparison-thread.html
Posted By For Type Date
1993 4x4 7.3 diesel swap with a 351W - Pirate4x4.Com : 4x4 and Off-Road Forum This thread Refback 01-16-2016 03:53 PM
