2011 6.7 torqshift noise - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 08-14-2017, 11:43 PM Thread Starter
<---F350 DRIFTER
drwoodchopper's Avatar
For the last month or so my transmission has been making a high pitch "squealing" type noise in second gear. There does not seem to be any real pattern to it. It did it 4 times today and hasn't done it for a few days. There does not seem to be any physical/mechanical symptoms. It seems to do it most often when making a turn. I have occasionally heard it start to squeal in first right before it shifts. No codes and no drivability issues. I have been unable to make it do it under heavy throttle as well.
Any ideas? Only issue I have had is on very rare occasions it will take several seconds to go into reverse. It will go months without doing that.
97
PSD. CC 4X4 195K, IDM mod, 6 Leaker IC, DP Tuner 6pos chip, WOP QSSB Turbo, kit by Carson Stauffer. Swamps 175/146's sticks, CNG kit 35mpg's on the diesel, E-fuel, Adrenaline and converted to a ZF5. RSK rolling on 35's. 4" straight pipe. 2011 f350 ccsb leveled on 35's, I can neither confirm nor deny that it is tuned and deleted!
drwoodchopper is offline
post #2 of 5 (permalink) Old 08-15-2017, 03:42 AM Thread Starter
<---F350 DRIFTER
Re: 2011 6.7 torqshift noise
I went out tonight and did a bunch of start and stops and put it into manual mode and started in second. I was able to make the same steel type noise. Only in second gear..
97
post #3 of 5 (permalink) Old 08-16-2017, 08:40 PM Thread Starter
<---F350 DRIFTER
Well it doesn't look like anyone has experienced this issue on here. I was able to recreate the noise which more accurately sounds like a fan belt squealing. It sounds like it is coming from dead center of the transmission, occasionally it sounds electrical in nature which is leading me towards a solenoid issue. Hopefully it is not something internal. Drove 240 miles today and it made the noise a few times but continues to work flawlessly. I would say it shifts a little on the firm side in the morning when cold and has done that since new. Hope to get an idea of what it could be before I take it in and they tell me nothing is wrong with it....or i need a 8k trans!
Any thoughts?
97
post #4 of 5 (permalink) Old 08-22-2017, 06:07 PM Thread Starter
<---F350 DRIFTER
Dealer diagnosed it as a leaking exhaust manifold.
97
post #5 of 5 (permalink) Old 08-23-2017, 01:45 AM
Thanks for the follow up.
2012 F-250 XLT Crew Cab 6.7l
Tuxedo Black
3.55 E-Locker..Timbrens
TCNashville is offline
