Odd 5r110 problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By harlo
post #1 of 7 (permalink) Old 07-10-2017, 02:52 AM Thread Starter
Odd 5r110 problem
My truck has a strange issue. It has been doing it on and off for months now and seems to be getting more consistent. And only seems to do it after it's warm and sitting for a short amount of time. Like shutting it off then running into the store and jumping back in it.
The issue is when I put it in drive you can feel it go into gear and try to move but feels like you are against a curb. If I tap the throttle it will jump/clunk into gear and be fine. Only does it the one time after a warm start. Always goes into reverse fine and shifts normal when driving. When I loaded a new tune it seemed to fix it for a couple weeks but came back.
Anybody had similar problems? I'm thinking a sticking solenoid but not sure which ones do what and when.
harlo is offline
post #2 of 7 (permalink) Old 08-03-2017, 01:51 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Odd 5r110 problem
This is a new one on me. I don't know what would cause that.
Mark
Mark Kovalsky is offline
post #3 of 7 (permalink) Old 08-04-2017, 02:12 PM Thread Starter
Thanks for chiming in. I'm thinking about just throwing in a new line pressure solenoid to see if that changes anything
harlo is offline
post #4 of 7 (permalink) Old 08-08-2017, 09:54 PM Thread Starter
I finally got around to checking line pressure. It was a cheapy gauge so not sure on accuracy.
At idle they were
Park 45-50psi
R. 75
N. 45-50
D. 70
3. 75
2. 75
1. 75
At stall it would only go up to about 150psi
Going down the road it would get up to 220psi when on it. I have a tow tune loaded in it now.
harlo is offline
post #5 of 7 (permalink) Old 08-09-2017, 02:15 AM
Reverse idle pressure is a little low, everything else is fine. Stall pressures are WAY low. Try a new line pressure solenoid.
Mark
post #6 of 7 (permalink) Old 08-11-2017, 01:02 AM Thread Starter
I ordered the line pressure and a stock direct solenoid for it. I found other threads about people having similar problems after putting in a modified direct solenoid which I put in mine years ago.
harlo is offline
post #7 of 7 (permalink) Old 09-08-2017, 05:27 AM Thread Starter
Well after reading many posts of people having a similar problem after installing a gogo modified direct solenoid I remembered that I put one in 6 or so years ago. So I ended up changing the direct and line pressure solenoids with OEM ford ones and it took care of the problem. It's been 1000+ miles since I fixed it and still good. Truck goes into gear instantly now. I always had a second or so delay even on a good day. Thanks for the help!
Mark Kovalsky likes this.
harlo is offline
