4r100 no 4th gear and od light always on - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 07-02-2017, 09:35 PM Thread Starter
Currently chasing an issue i'm having with my 4r100 its not shifting into 4th gear I had some issues where it wouldn't go into 4th gear but after cruising for a few minutes I could restart the truck and have 4th, other times I wouldn't have any issues. Now i'm getting no 4th gear and it seems that it came right around the time that I replaced a broken column shift tube and lever... My OD light is also now stuck on... I checked the wires at the plug and the red/yellow is 12v as it should be but the white/green is at 12v and the brown/white is 8v
I Also recently had the trans rebuild replacing just about everything including solenoids
01 7.3 Ext Cab XLT.
ARP Headstuds,TB 5 inch MBRP / Bellowed up pipes, WW, Afe Stage 2, and more
99 7.3 ats/suncoast trans, ATS 38R, WW2, regulated fuel return, Fass 150, Snows water meth, 160cc injectors, Adrenaline Hpop, ARP's dp Infinity and more.
07 6.0 CCLB - stock
07 6.6 LBZ Duramax "dually"
International 4300 DT 466, 4200 VGT 365
F750
HunterD is offline
post #2 of 14 (permalink) Old 07-03-2017, 02:20 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 4r100 no 4th gear and od light always on
You should check the wires to the OD button for damage. Checking the voltages doesn't tell me anything. Look for continuity from one end to the other, and for shorts to ground and to power.
Mark
Mark Kovalsky is offline
post #3 of 14 (permalink) Old 07-03-2017, 02:29 PM
Master BS'er
jamiesaun's Avatar
What? Voltage tells you everything. It is by far the most accurate and quickest way to check a circuit. Especially if you know how the circuit is controlled.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #4 of 14 (permalink) Old 07-03-2017, 06:05 PM
Great! Tell him what's wrong.
Mark
post #5 of 14 (permalink) Old 07-03-2017, 06:33 PM
Master BS'er
jamiesaun's Avatar
Oops. Someone's got a frownie face. lol.
Brother James
post #6 of 14 (permalink) Old 07-04-2017, 11:58 AM
Voltages are good to know, but don't always tell the answer. I can't tell what's wrong from the voltages he posted, can you?
If I knew if each of the wires had continuity and if any were shorted to ground or power I could tell him how to fix the problem.
Mark
post #7 of 14 (permalink) Old 07-04-2017, 01:27 PM
Master BS'er
jamiesaun's Avatar
No sir, not without a diagram I can't. Ya got me there. So that parts true enough Mark, I can buy that.
I was just saying voltage is really the king, and is a real time reading of not only the supply, but also the continuity and resistance. But, that's true that it tells ya nothing without a reference of some kind.
Brother James
post #8 of 14 (permalink) Old 07-04-2017, 01:42 PM
Master BS'er
jamiesaun's Avatar
What if the wires turn out to be fine? What then? Is there a way to condemn the switch or module without using voltage?
I will say that 8v sounds a little strange for an two position switch. Could be perfectly normal for this circuit, I can't answer that right now, but if it is normal, it would be uncommon for sure. It's also a little strange that all three wires have a voltage in them.
Brother James
post #9 of 14 (permalink) Old 07-04-2017, 11:54 PM
longjonsilver's Avatar
Continuity is one thing .the circuits ability to carry the current is another thing . In the shop we load the circuit with a small light bulb from a lawn tractor . If it glows you know it's good . I agree with Mark , voltage is only part of the puzzle .
Cheers !
longjonsilver is offline
post #10 of 14 (permalink) Old 07-04-2017, 11:55 PM
