Clutch Suggestions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 02-16-2010, 04:17 AM Thread Starter
Travelin PhotoG
Lonald's Avatar
Send a message via AIM to Lonald Send a message via Yahoo to Lonald
Clutch Suggestions
Ok so Stock Clutch is not going to hang in there much longer, Ive been looking at the Valair Clutchs, and need to know what would be the best suggestion as to which one
My mods are in the sig,
mods to come
38R Turbo
Swamps Tow injectors
Now I tow alot with this truck, most of the miles I drive are with my 5th wheel behind it.
99.5 F-350 CC Dually, 4x4 6 spd, 08' Mirrors, GearHead Tuning, AFE Stage II, Garret 38R, 4" Exhuast, some gauges, Ranch Hands / 2007 Forest River Work N Play 34' fifth wheel
Lonald is offline
post #2 of 13 (permalink) Old 02-16-2010, 04:30 AM
Re: Clutch Suggestions
i have a valair full ceramic button clutch in my truck, before that i had a full kevlar and i didn't like it at all because i told the guys right at valair i do a little towing with the truck and they thought that the kevlar was the solution and it turned out that there is no showing off with it strictly towing and i just took it back out and they replaced it for me and i'm very satisfied with it (ceramic) i would recomend the full kevlar clutch if you just tow it has a very smooth engagement and it can hold a decent amount of hp if you want to show off with the kevlar clutch i wouldn't recomend it to you cause it can hold the hp once the clutch is engaged dropping the clutch doesn't work with the kevlar it just burns it up if you want more show off you can get the kevlar/ceramic clutch little cheaper than the full kevlar
fordpower2008 is offline
post #3 of 13 (permalink) Old 02-16-2010, 04:32 AM Thread Starter
Travelin PhotoG
Lonald's Avatar
What are you meaning by "showing off?" lol
Lonald is offline
post #4 of 13 (permalink) Old 02-16-2010, 04:37 AM
the kevlar clutch isn't meant to be slipped very much at all, showing off i mean like dropping the clutch anything relating to beating on the clutch
post #5 of 13 (permalink) Old 02-16-2010, 04:53 AM Thread Starter
Travelin PhotoG
Lonald's Avatar
ahhh, this is my first 6 spd, I slip the clutch, usually not paying attention, lol
Lonald is offline
post #6 of 13 (permalink) Old 02-16-2010, 04:57 AM
ya like a little bit of slipping isn't bad but just if you wanted to drop the clutch or something like that it doesn't hold up to that
post #7 of 13 (permalink) Old 02-16-2010, 04:59 AM
if i were you i would go with the ceramic/kevlar cause if you are going to have more mods in the future just might as well get done the way you want the first time
post #8 of 13 (permalink) Old 02-16-2010, 05:10 AM Thread Starter
Travelin PhotoG
Lonald's Avatar
This one?
13" x 1.375" Performance Replacement
Ceramic / Kevlar Buttons (both sides of disc shown)
HD Spring Hub
Rated @ 500HP / 1000 ft lbs Torque
3400# Pressure Plate
Kit includes:3400# Pressure Plate, Clutch Disc, Release Bearing, Pilot Bearing and Alignment Tool.
Lonald is offline
post #9 of 13 (permalink) Old 02-16-2010, 12:01 PM
The Fireman
big_stroker's Avatar
I will be going with the Valair full ceramic for my next clutch
big_stroker is offline
post #10 of 13 (permalink) Old 02-16-2010, 03:18 PM
yup that's the one
