4r100 filter change question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 02-11-2010, 10:40 PM Thread Starter
Going to do a filter change next week and also drain the TC. Just wondering how much fluid i'm going to need to fill it back up? I bought a case but want to make sure that will be enough.
2000 F-350 ccsb 4x4: DIY intake, 4 inch straight, Tuning by [email protected]
99 tacoma V6 5sp 4x4: Chaos/DR mid travel kit, F/R glass, 33x12.50 MTR's---Sold
08 F-150 Lariat Screw 4x4:---Sold
2005 F-250 Lariat ccsb 4x4 auto: All stock for now
Stroke00 is offline
post #2 of 11 (permalink) Old 02-11-2010, 11:16 PM
CLARKY
smokinndstrokin's Avatar
Re: 4r100 filter change question
I cant remember exactly how much i used when i serviced my trans last, but for sum reason 17 qts sticks in my mind..?Maybe more or less i really dont remember
2001 F350 SD K&N intake tube w amsoil filter nd prefilter,4in turbo back to 6in tip,TS chip,,isspro guages(poost,pyro,trans)AIH delete,CCV, Dr.evil trans w 3 disk lock up converter by Hughes,wicked wheel,Mag hytec covers with many more mods to come
smokinndstrokin is offline
post #3 of 11 (permalink) Old 02-11-2010, 11:56 PM
Caption This
444-4D's Avatar
12 isn't enough. I've done mine twice and if you are patient with the draining you will need 16.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #4 of 11 (permalink) Old 02-11-2010, 11:58 PM
white7.3's Avatar
What kind of fluid are you guys using???
2001 F-250 4x4 ECSB
7.3 PSD DP Tuned
6.0 I/C Van Turbo & WW
6637 Intake 5" Exhaust
Custom RR Fuel System
05 Grille/08 Center Console
Raptor 372 w/ Toyo Open
Country AT2 35/12.50
white7.3 is offline
post #5 of 11 (permalink) Old 02-11-2010, 11:59 PM
Caption This
444-4D's Avatar
I use the red stuff.
444-4D is offline
post #6 of 11 (permalink) Old 02-12-2010, 12:06 AM
Edward Scissorhand WanaB
Bushwakd's Avatar
There is a Sticky at the top of the forum page with flush procedure and ATF quantity.
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #7 of 11 (permalink) Old 02-12-2010, 03:26 AM Thread Starter
Ok thanks guys. Guess i will pick up a few more quarts before i do it.
Stroke00 is offline
post #8 of 11 (permalink) Old 02-12-2010, 11:02 PM
CLARKY
I run Mobile 1
post #9 of 11 (permalink) Old 02-14-2010, 01:24 AM
tbolt's Avatar
Buy a motorcraft filter. The ones from az and other stores don't fit right. The shop I use has found several that came loose, didn't fit the grommet tight enough and the filter was on the bottom of the pan. A few bucks more is worth it. I use mercon v and tow heavy and no problems.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #10 of 11 (permalink) Old 02-14-2010, 03:16 AM
Caption This
444-4D's Avatar
I've not bought one from Autozone but I've bought them from Napa and Ozark and they were the same filter as the OE filter. They were boxed by ATP. The grommet doesn't support the filter. It rests against the bottom of the pan. Ford added some dimples to the pan, after making it for a couple of years without them, to better hold it in place.
444-4D is offline
