Trans problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 02-09-2010, 03:53 AM Thread Starter
spb_2006's Avatar
Trans problems
Everytime I shift into 2nd gear it grinds, unless I really granny shift it...any ideas on what it is? Its only in second gear and it only started after I had my new south bend clutch put it.
spb_2006 is offline
post #2 of 3 (permalink) Old 02-09-2010, 11:58 AM
compresion ignition adict
STORMTROOPIN's Avatar
Re: Trans problems
Syncros.... thats what it sounds like to me. im sure some else will chime in.
04' F350 cummins conversion 12v/ZF6...
STORMTROOPIN is offline
post #3 of 3 (permalink) Old 02-09-2010, 09:58 PM
Transmission Junkie
Re: Trans problems
You need to check clutch release. If it just started when you installed the clutch then I would start there. The transmission may still need to be repaired but clutch release is probably the culprit.
08 F350 CC Dually, SCT Livewire, DPF/DOC Delete Precision Converter and Performance Powertrain transmission
Performance Powertrain Inc.
Specializing in Performance Ford Transmissions
5R110/4R100/TR3650 and more...
(765)716-2291
02Bluestroker is offline
