Trans Cooler Lines sizes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-08-2010, 06:27 AM Thread Starter
PSD
CNDiesel's Avatar
Im putting in a E4OD into my truck, the trans is from a 97. The only thing left todo is to bend up new Trans cooler lines. Anyone know what size of tubing I should get?
1996 crew cab long box. 3.73s, auto 493/1135 stockish auto trans.
CNDiesel is offline
post #2 of 8 (permalink) Old 02-11-2010, 12:28 AM Thread Starter
PSD
CNDiesel's Avatar
Re: Trans Cooler Lines sizes
anyone?!
CNDiesel is offline
post #3 of 8 (permalink) Old 02-11-2010, 02:14 AM
cemeyer's Avatar
stock is 5/16.
Curt
97 350 CC LB 4x4
Injectors, oil, H2E, studs, 910's, idm, etc...
cemeyer is offline
post #4 of 8 (permalink) Old 02-11-2010, 02:31 AM
sick97psd1's Avatar
Send a message via AIM to sick97psd1
If I were you I would go with SD lines, they are bigger diameter and with help flow/cool better than the obs lines. I am in the process of doing this now since I do heavy towing and plowing with my truck.
sick97psd1 is offline
post #5 of 8 (permalink) Old 02-11-2010, 06:04 AM Thread Starter
PSD
CNDiesel's Avatar
I have a roll of 3/8" Hard line. I dont have any of the fittings for the line to trans. I guess I would have to find larger fittings?
CNDiesel is offline
post #6 of 8 (permalink) Old 02-11-2010, 09:14 AM
< YOU WISH...
SINNER's Avatar
The fittings on the Trans are based on the line size. They are a inverted flare. That said you will need to use a reducing coupling a few inches away from the connection as you can not just put on a larger fitting. The flared tube makes the seal, the captive nut goes over the tube just to hold it in place.
Originally Posted by Coltaine View Post
It feels like someone just had forced buttsecks with my eyes.
**no links for non site sponsors please**
SINNER is offline
post #7 of 8 (permalink) Old 02-12-2010, 12:34 AM Thread Starter
PSD
CNDiesel's Avatar
Ok thanks. Ill go get some 5/16 lines then.
CNDiesel is offline
post #8 of 8 (permalink) Old 02-12-2010, 01:41 AM
What diameter are the SD lines and do they have to be hard (i.e. steel) could you run flexible....say hydraulic line? Would 1/2" id line be too big? Still chewing on my V10 cooler setup and am thinking bigger is better (1/2") but need more input...
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
