ZF-6 No shift after sitting - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-10-2017, 03:06 AM Thread Starter
Hey guys, New the forum. Hoping to find some input on an issue with my old 7.3
I parked the truck around a year ago due to some engine problems. I then went out and purchased a bone stock, well maintain 06' 6.0. Today I went out to move my old 7.3 into the shop. Got it fired up but when I put it in gear nothing happens. I can run through all the gears from reverse to forward with no grinding as if the truck is not even running. I know there is no major transmission issues since I drove it to where it is currently parked. Any ideas please let me know. The truck is a 2000, F350, 4x4.
Dieselfarm is offline
post #2 of 4 (permalink) Old 04-10-2017, 05:17 AM
Re: ZF-6 No shift after sitting
Someone stole your driveshaft?
Perhaps the clutch hydraulic system won't release for whatever reason?
1999 7.3, Auto, 4x4, Ext. Cab
firehawk618 is offline
post #3 of 4 (permalink) Old 04-10-2017, 03:02 PM Thread Starter
No one stole my driveshaft, I crawled around under the truck looking for anything obvious.
Not sure, typically my experience is if a hydraulic clutch system is failing it will not disengage the clutch properly and this is completely opposite. I've had clutches not fully engage, clutches not fully disengage but never had this before. It's as if the input shaft is not spinning but I drove it to where where it's at now. Wondering if anyone else has experience anything similar or has any ideas on what it could be.
post #4 of 4 (permalink) Old 04-10-2017, 03:29 PM
Moderator
Sbluke55's Avatar
Check your t case to see if it's in neutral
01 f-250, Standard
Sbluke55 is offline
