o/d lite flashing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 02-07-2010, 01:31 PM Thread Starter
bluedge8's Avatar
o/d lite flashing
I have a 2002 e350, it has p1754 code, I just don't know where to start diag it. I read the diag chart but it doesn't tell me where to really start. I will assume the wiring is not actually shorted. and that most likely the coast clutch solenoid is failed. can I replace it on my own? I'm fairly mechanical but haven't been into transmissions much. thanks
1997 f250 4x4 sclb, auto, 3.55's, 191k, diy intake w 6637, ccv mod, pyro, boost, trans gauges, 3" dp to 4" single exh. super chips for now. scangauge
Originally Posted by jdc753 View Post
Besides there is absolutely no way to idiot proof something, since they are always coming out with better idiots by the day
bluedge8 is offline
post #2 of 5 (permalink) Old 02-07-2010, 03:52 PM
NorCalDiesel's Avatar
Re: o/d lite flashing
It's difficult to diagnose without the Ford scanner or a scanner that will run the OTM testing. The solenoids are all in one "solenoid pack" that is replaceable. Using a DVM you can test each solenoid at the transmission harness connector. I checked a few out of the vehicle and it is easy. I don't know if you will be able to get to the connector visually to be able to hit the different pins to check the solenoid pack with the pack installed
I attached a diagram of the transmission wiring harness connector. The connector at the tranny that you plug the harness into is the solenoid pack. Pins 1 and 5 are the coast clutch solenoid pins. Look for 20 - 30 ohms across those two pins. All the solenoids in the pack except the TCC PWM (pins 1 and 4)should read within the same resistance range of 20 - 30. The TCC PWM Solenoid should read 10 -20 ohms
2002 X PSD, Billy Boat 4", AirRaid, 38R,HO Outlet, IH Up-pipes, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp, Oil PSI at Turbo Pedestal
DP-Tuner 6 pos No Start - 140
Super Heavy Duty 4R100 / triple disc from ATO
Transmissions in Sacramento
ICON 5" Spring Pack Lift
PSC Ram Assist Steering
NorCalDiesel is offline
post #3 of 5 (permalink) Old 02-07-2010, 08:21 PM Thread Starter
bluedge8's Avatar
thanks for the info. I won't get to it right away but all info will help. thanks again.
bluedge8 is offline
post #4 of 5 (permalink) Old 02-08-2010, 10:57 PM
mnstroker's Avatar
I got a Scanguage coming in the mail, I can come over and hook it up and we can pull the codes for you. Give me a call if you want 320-761-3166.......Chad
Back to stock for now.
Originally Posted by 1800joedaddy View Post
It's one thing to get cornholed... its another to pay for the cornholing!
mnstroker is offline
post #5 of 5 (permalink) Old 02-09-2010, 02:46 AM Thread Starter
bluedge8's Avatar
did you get in on the group buy from big stroker? if so I have one on order from him as well. He is supposed to order on wed. and hopefully we will see them soon.
bluedge8 is offline
