OD Light - Trip Reset? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-03-2017, 02:09 PM Thread Starter
1997 F-250 HD 7.3.
Intermittent OD light flashes and transmission shifts hard. When is happens, if I reset the trip meter, everything goes back to normal. Does this make any sense? Already changed vss and pigtail and cleaned inside rear diff. Do I need a new cluster/psom??
dkl236 is offline
post #2 of 4 (permalink) Old 04-04-2017, 01:44 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: OD Light - Trip Reset?
No, that doesn't make any sense. Are there any codes stored when the light flashes?
Mark
Mark Kovalsky is offline
post #3 of 4 (permalink) Old 04-04-2017, 11:11 AM Thread Starter
Code was for vss sensor. Changed sensor and pigtail. Since vss is wired into psom along with odometer, I thought maybe there was a psom issue?
dkl236 is offline
post #4 of 4 (permalink) Old 04-05-2017, 02:15 AM
There may be a PSOM issue.
Mark
