Tranny swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-26-2017, 03:22 AM Thread Starter
Tranny swap
can I put a 03 1ton 5r110 in a 06 3/4ton with 5 r110. Is tcm and harnesses the same
Rattyfunk is offline
post #2 of 4 (permalink) Old 03-26-2017, 03:54 AM
Moderator
Sbluke55's Avatar
Re: Tranny swap
I believe so. Lets see if @Zmann knows.
01 f-250, Standard
Sbluke55 is offline
post #3 of 4 (permalink) Old 03-28-2017, 01:19 AM Thread Starter
Re: Tranny swap
From my understanding it would fit. Was hoping to get some solid info
post #4 of 4 (permalink) Old 03-28-2017, 12:41 PM
alleged moderator
tjctransport's Avatar
Re: Tranny swap
as long as the transmissions both are from the same engine.
as in diesel to diesel, or gas to gas. a gas trans will not bolt to a diesel block.
there is no difference between F250 and F350, they use the same engine, trans, frame, and everything else. the only difference is the 250 uses 2 inch rear blocks and the 350 uses 4
tom
tjctransport is offline
