Recommendations on a transmission shop near Denver? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-17-2017, 07:42 PM Thread Starter
I have a ZF6 with a 4th-5th gear grind and a tail housing in need of replacement. Looking for a reputable shop to do the work. Shops are a dime a dozen... looking for one that knows these transmissions well.
Thanks in advance.
beef tits is offline
post #2 of 7 (permalink) Old 03-17-2017, 07:53 PM
Moderator
Sbluke55's Avatar
Re: Recommendations on a transmission shop near Denver?
Maybe @410customs will know. If not there is a colorado chaptor over on powerstroke.org. they might know.
01 f-250, Standard
Sbluke55 is offline
post #3 of 7 (permalink) Old 03-17-2017, 07:58 PM
Moderator
Sbluke55's Avatar
Also i have this urge to call you udders.
01 f-250, Standard
Sbluke55 is offline
post #4 of 7 (permalink) Old 03-17-2017, 09:03 PM Thread Starter
Ha, thanks.
At this point you can just call me moron... this damn truck ended up being a much bigger project than I intended!
post #5 of 7 (permalink) Old 03-17-2017, 09:12 PM
410customs's Avatar
Its allright man just see it through!! Once completed then she will be all yours and better than ever
I do not know any 5-6 speed builders in Denver area, I rebuild my own transmissions with the help of a good friend of mine, and he has 2 in the que as of today!
Have you considered buying a new one and swap them out? This is something I can do at my shop if you go that route?
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #6 of 7 (permalink) Old 03-17-2017, 09:24 PM
Moderator
Sbluke55's Avatar
The 4-5 shift could be caused by the cracked tail housing. I would change it out. Or just swap to a new or used zf6. Sometimes they come up for sale in craigslist.
If you didnt know im just over the mountain in grand junction. If i find one here ill let you know
01 f-250, Standard
Sbluke55 is offline
post #7 of 7 (permalink) Old 03-17-2017, 10:01 PM Thread Starter
I call it 4-5 shift, but I guess it's a 5-6 shift! (who uses the granny gear in normal situations anyway?)
I suspect bad synchros. The tranny had a lot of coolant in it... for how long? I do not know. Radiator has been replaced but while it is out... I think I will hedge my bets and just have it gone though. A-1 Trans came recommended by a diesel speed shop. They quoted $1100 to go through it. Didn't seem too bad.
I also have a South Bend 350hp clutch/flywheel and a new clutch fork on the way :)
For never having owned a ford truck in my life I sure am learning a lot awfully quick... mostly never to buy another one! I've had this thing 3 weeks. Paid $4k for it thinking I might put another $4-5k in it... more like another $10k... Going broke over here.. Haha.
