slave cylinder problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 02-04-2010, 06:11 PM Thread Starter
learnin the hard way
97strkr's Avatar
Okay so I have a 97 with a 5 speed and the slave cylinder keeps going out yesterday I had two go out on me and the neutral safety switch doesn't seem to want to engage unless u slam the clutch to the floor but if u do that then the slave cylinder gives out I put a new master cylinder in yesterday as well. The clutch that is in the truck isn't factory its a zoom the previous owner installed that so my question is does any one know of a permanent fix or do I just need to stock up on slave cylinders thanks
2006 F250 Lariat
EGR Delete
MRBP
Blue Spring
S&B Intake
CFM +
SCT
Autometer Factory Matched Guages
97strkr is offline
post #2 of 6 (permalink) Old 02-04-2010, 10:59 PM
That thing got a Cummins?
nasty96's Avatar
Re: slave cylinder problem
I'd get the whole hyd system from ford and install. Comes prebleed and ready to roll. The price is very resonable
Ford makes it
, I break it
1996 F350 CCLB 4x4 Broke Built Auto
2000 Dodge 3500 5 Speed 4x4 450k and Counting
2001 Dodge 3500 6 speed 4x4 Fully loaded
nasty96 is offline
post #3 of 6 (permalink) Old 02-05-2010, 12:03 AM
OverFuelingForYourPlesure
pontiacross's Avatar
what I am running is is this thread
ZF5 master cylinder upgrade - Powerstroke Nation
as for the neutral safty I bypassed that but you may just need a new switch, but check and see if there is abunch of play under the dash in the linkage and where it pivots
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
post #4 of 6 (permalink) Old 02-05-2010, 12:24 AM
Dairy Mechanic
Magnum PD's Avatar
Have you tried the NAPA cylinder? It's bigger than others.
96 Ford F-350 200 cc's, Electric fuel system, TS chip, 17 oil pump, Banks intercooler, 3" intake manifolds, SNOW Water-Meth system, South Bend DxD 3600, Banks brake, 4" stacks. Tuff country ladder bars.
IH RULES Not a 6.0 fan, engine out right now.
Magnum PD is offline
post #5 of 6 (permalink) Old 02-09-2010, 11:47 PM Thread Starter
97strkr's Avatar
no i havent tried the napa one out yet and i have heard some several people about that prebled system from ford so i think ill give that a try thanks for the help
2006 F250 Lariat
EGR Delete
MRBP
Blue Spring
S&B Intake
CFM +
SCT
97strkr is offline
post #6 of 6 (permalink) Old 02-10-2010, 12:05 AM
cattle farmer
powerstroke742008's Avatar
there are two wires that you can wire together to make it to where you dont need to puch the clutch in to start it.(this can be dangerous but you need to be smart)
Thomas,
97 f350 cclb-7.3
sticks,clutch,bars
05 f350 cclb-6.0
deleted, studed
powerstroke742008 is offline
