ZF5 TRANS ON A 2000 POWERSTROKE CLUTCH QUESTION - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-01-2017, 11:32 AM Thread Starter
i have a 2000 f350, i want to put the zf5 behind it, im having trouble finding a clutch, if i understand the zf5 and zf6 both where 10 spline, but slightly different shaft size. im sure its covered somewhere on here im just not having any luck finding it so and info would be great!!! Thanks
wredge is offline
post #2 of 8 (permalink) Old 03-01-2017, 12:41 PM
Moderator
Sbluke55's Avatar
Re: ZF5 TRANS ON A 2000 POWERSTROKE CLUTCH QUESTION
Just order a clutch for a 94-97. Get one with a new flywheel. I suggest south bend.
01 f-250, Standard
Sbluke55 is offline
post #3 of 8 (permalink) Old 03-01-2017, 12:54 PM Thread Starter
Well that was quick and easy, thank you!!
wredge is offline
post #4 of 8 (permalink) Old 03-01-2017, 01:02 PM
Moderator
Sbluke55's Avatar
Anytime. Be sure to replace the clutch for while your in there.
01 f-250, Standard
Sbluke55 is offline
post #5 of 8 (permalink) Old 03-01-2017, 01:04 PM
alleged moderator
tjctransport's Avatar
get a setup for a 99. the early 99 trucks came with the 5 speed option.
tom
tjctransport is offline
post #6 of 8 (permalink) Old 03-01-2017, 01:45 PM
410customs's Avatar
the clutch fork? Do they wear down?
I am happy with my Luk clutch it seems to work very well
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #7 of 8 (permalink) Old 03-01-2017, 01:59 PM
Moderator
Sbluke55's Avatar
No they tend to break. There is a new design.
01 f-250, Standard
Sbluke55 is offline
post #8 of 8 (permalink) Old 03-01-2017, 07:30 PM
410customs's Avatar
well crap now you tell me! mine is OEM 1997 F350 right now
21.9 liter family
