shifter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 02-02-2010, 09:40 PM Thread Starter
Buy more Budweiser
shifter
will the ball on the end of the gearshift screw off pretty easy on a 2000?
budman is offline
post #2 of 6 (permalink) Old 02-02-2010, 10:51 PM
Pdt1081's Avatar
Send a message via AIM to Pdt1081
Re: shifter
If you're asking about a shift knob for a 6sp, they don't screw on/off. They're a press fit. It shouldn't be all that difficult to remove though. Mine is siliconed in place because it came off in my hand once.
Pdt1081 is offline
post #3 of 6 (permalink) Old 02-02-2010, 11:24 PM
co04cobra's Avatar
Re: shifter
sometimes they can be a pita sometimes they fall off. Ive used a tierod fork to get them off before.
co04cobra is offline
post #4 of 6 (permalink) Old 02-02-2010, 11:30 PM
Edward Scissorhand WanaB
Bushwakd's Avatar
Re: shifter
Your shifter rod is spline at the top where the nob ball connects. The shift nob ball when new has a plastic inside that does not have splines. Every 3 or so years I have to replace the shift nob because the plastic inside strips out. Since the shift nob does not have any splines and the shift rod does to install a new shift nob just whack in on there carefully not to crack the plastic insert.
With that being said the nob comes off. Will it stay on if you take it off and decide to put it back on probably not. As mentioned mentioned above some silicone will help keep it on. I keep a spare in the glove box of my work truck as sometimes other employees like to yank it off from trying to speed shift.
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #5 of 6 (permalink) Old 02-02-2010, 11:33 PM
Bushwakd's Avatar
Re: shifter
If you want it off just strip the plastic insert and it will come off.
The shift pattern can easily be removed with a small metal pick.
Bushwakd is offline
post #6 of 6 (permalink) Old 02-05-2010, 12:12 AM Thread Starter
Buy more Budweiser
Re: shifter
I was kinda hoping that there were some threads on it so I could put a cool tap handle on that I found at work. oh well.thanks
budman is offline
