ZF6 weak point's? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 02-01-2010, 03:45 PM Thread Starter
Coming For You
"THE DEMIZE"'s Avatar
Send a message via Yahoo to "THE DEMIZE"
ZF6 weak point's?
I would like to know the weak points of the ZF6 trans Mine has 4k on it if the guy wasnt lying, but anywho I know the output shaft has broken in these with excessive HP.But in my app im running the DT466 and was told they can exceed 2k torque, Im going to run kenny's triple disc clutch. Im wanting to tear down the trans and do a full rebuild and heat treat the known weak points later in my build. any tip trick on this or info is greatly appreciated!
steve-0
97 F-350 cc lb 4x4
Swamps,Carson,Beans,Unlimited
"THE DEMIZE" is offline
post #2 of 7 (permalink) Old 02-01-2010, 11:32 PM Thread Starter
Coming For You
Re: ZF6 weak point's?
bump !
97 F-350 cc lb 4x4
post #3 of 7 (permalink) Old 02-02-2010, 02:00 AM
12v Ford's Avatar
The only company that I've heard of doing any type of performance type builds on these is Midwest transmissions. I don't have any info for them, but maybe someone else who knows will chime in.
Mine- 1995 Ford F-350 XLT CC 2wd DRW LB, ZF-6sp, '96 215 hp Cummins, SBDD, #10, SDX 5x14s, HE351cw/S475/1.10 twins, and other good stuff
My Newest-1995 Ford F-350 XLT CC 4x4 SRW LB, 460 gas, auto, Soon to be 12v Cummins, 4r100 and 700hp+
Wife- 2008 Ford F-350 Lariat CC SB 4x4 SRW, 20" factory wheels, navigation, sirius, all stock for now
12v Ford is offline
post #4 of 7 (permalink) Old 02-02-2010, 02:18 AM
cattle farmer
powerstroke742008's Avatar
iirc jason has found some weak points maybe he will chime in
Thomas,
97 f350 cclb-7.3
sticks,clutch,bars
05 f350 cclb-6.0
deleted, studed
powerstroke742008 is offline
post #5 of 7 (permalink) Old 02-05-2010, 11:06 AM
2010 BOB Points Runner up
Dieselfever's Avatar
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
Jason's center support section crack and push the bearings out if I remember right, hopefully he will chime in
-Michael
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
Dieselfever is offline
post #6 of 7 (permalink) Old 02-05-2010, 01:23 PM
HRT Performance
HotRodTractor's Avatar
I broke the #### out of mine! I did it when I launched off the line in a 3.0 class at 4500 RPMs running 2nd Hi. There was a bounce that is very noticable in the video coming from the rear end - but it wasn't as noticable from the cab and it felt more along the lines of the little bit of bounce that the always came from that truck during take off. I am sure the bounce didn't help the situation, but ultimately I completely blame the failure on having that transmission in 2nd gear. Everyone that trys to pull that gear twists the output shaft in two. Sure they might get away with it once or twice, but it will break from the torque.
I never did completely explain the bearing being pulled out of the middle plate, but I didn't investigate it very far other than the casting differences I found in the two transmissions I had on hand. I haven't heard of anyone else having this failure, so it very will could have been a fluke.
I posted up a thread about it a while ago with lots of pictures. Here
Just for fun here is the video of me braking the transmission in that thread.
I think its time I get another truck onto the track.........
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #7 of 7 (permalink) Old 02-05-2010, 03:20 PM Thread Starter
Coming For You
http://www.youtube.com/watch?v=HJ69Hg7TZlw
Im going to have to talk to evan also he has broke some zf6's And I know you have also.
I second another truck on the track !!! maybe a 70's excab with another psd swap !???
97 F-350 cc lb 4x4
