6.4 problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 01-28-2017, 01:44 PM Thread Starter
6.4 problem
So my 6.4 seems like it has completely lost its power. Keep in mind it is stock no tune exhaust or anything. From a dead stop it accelerates fine up until about 45 mph and some times it shifts hard out of what I'm think is 3 or 4th gear and sometimes it will rev up to about 2500 rpm and the speed and rpm just stalls. I have to let of the gas and ease back on it for it to go faster. The other day I was getting on the highway and the pedal to the floor and my speed was just slowly rising. I've had some people tell me the torque converter, clutch is slipping, or the exhaust filter is backed up. Can anybody help me out?
Jason K. Brannan is offline
post #2 of 7 (permalink) Old 01-28-2017, 07:46 PM
wackyman9's Avatar
Re: 6.4 problem
How many miles on it? Is it building boost?
-2008 Job #3 F250 CCSB 4x4
-Mishimoto Aluminum Radiator
-Peak Fleet Charge Purple Coolant
-SCT X4 Babysitter
-17" XD Addicts
-285 General Grabber AT2's
-Power Service White in the Tank
-Moog Tie Rods and Drag Arm
-Drilled and Slotted Rotors
-GearBoxZ DPF-R 4.0
-Flo-Pro DOC/DPF delete
-MPD CCV Kit
-Injen Evo CAI
wackyman9 is offline
post #3 of 7 (permalink) Old 01-28-2017, 09:06 PM
Re: 6.4 problem
Are you tuned? Are you seeming any codes.. If you are all stock, maybe a good idea to get a code reader on it, if you are close to Harrisburg, Pa. I can help. With info provide we can only guess. ????
My09Ride is offline
post #4 of 7 (permalink) Old 01-29-2017, 03:50 PM Thread Starter
Re: 6.4 problem
no tune and no check engine light or anything. im starting to wonder if the guy that had it before me had a tune on it because I'm starting to think it has something to do with the computer because the truck runs better before the transmission warms up than it does after it's warm.
post #5 of 7 (permalink) Old 01-29-2017, 03:51 PM Thread Starter
Re: 6.4 problem
170,000 miles and yes it seems to be building boost fine.
post #6 of 7 (permalink) Old 01-29-2017, 04:08 PM
wackyman9's Avatar
6.4 problem
If you can find a tuner or scanner that lets you navigate a little bit, I would clear your KAM. That will reset the trans computer.. also at 170k I would definitely be dropping the dpf at least for a cleaning with a pressure washer and inspection.. if it's not breathing, it's not running well...
Also, I believe when you hit 45mph on the 6.4 that's the switch over from the low pressure turbo to the high pressure turbo. Hopefully some one can verify this?
-SCT X4 Babysitter
-17" XD Addicts
-GearBoxZ DPF-R 4.0
-MPD CCV Kit
-Injen Evo CAI
post #7 of 7 (permalink) Old 01-29-2017, 04:17 PM Thread Starter
Re: 6.4 problem
It's just weird because sometimes it runs pretty good and then I can go in a store or something and when I get back in it I almost have to drive it like a manual by letting off the gas and easing back on so the transmission will change gears.
