Trans swap from auto to 6sp manual - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 40 (permalink) Old 01-27-2010, 07:57 PM Thread Starter
3YLSYKR's Avatar
Is this possible in my truck? Has anyone done this?
I was told that I couldn't unless I bought a new cab because they are shaped differently. Is this true?
8" Lift
38" Toyo MT's
DIY Traction Bars
Zoodad-AIH Delete-Foil Delete
Adjust. Wastegate
ISSIPRO Performax Gauges
4" TB Magnaflow Exhaust w/ 5" tip
AFE stage 2 PG 7 W/Pre-Filter
Superchips Prgmr 150HP/225TQ
Oil X-over Line
Smoked Lights w/LEDs & HIDs
DIY 3 stage Water/Meth
CCV
6.0 IC
Transgo Shift Kit
Derale Trans. Frame Rail Cooler
3YLSYKR is offline
post #2 of 40 (permalink) Old 01-28-2010, 03:40 AM
All done now
Arisley's Avatar
Re: Trans swap from auto to 6sp manual
You can do it, been done lots of times. The PCM will even work if I am not mistaken.
Arisley is offline
post #3 of 40 (permalink) Old 01-28-2010, 03:45 AM
co04cobra's Avatar
Yea you can def. do it honestly probably the easiest way to do it is buy a donor 6spd truck as you would have a fortune in just buying parts and the floorborads are different not the cab. You need a section of floor board from a manual truck. But has been done many times.
co04cobra is offline
post #4 of 40 (permalink) Old 01-28-2010, 03:45 AM
All done now
Arisley's Avatar
And that section is a patch, correct?
Arisley is offline
post #5 of 40 (permalink) Old 01-28-2010, 03:46 AM
just a welding fool.
Hawker's Avatar
like Marty has said before... the six speed swap is overrated. (i think he said that. somewhere... )
going from the six speed to an auto, the only reason i could see the hand shaker for is towing. traffic and in town driving is terrible.
Swamps
Gearhead Tuning
Diesel Innovations
Hawker is offline
post #6 of 40 (permalink) Old 01-28-2010, 05:14 AM
Travelin PhotoG
Lonald's Avatar
Send a message via AIM to Lonald Send a message via Yahoo to Lonald
Its horrible driving in traffic... but god I love it pulling my fifth wheel
99.5 F-350 CC Dually, 4x4 6 spd, 08' Mirrors, GearHead Tuning, AFE Stage II, Garret 38R, 4" Exhuast, some gauges, Ranch Hands / 2007 Forest River Work N Play 34' fifth wheel
Lonald is offline
post #7 of 40 (permalink) Old 01-29-2010, 03:20 AM
co04cobra's Avatar
People do it b/c it makes the truck more reliable for everyday use. And its not a bolt in plate in the SDs you have to actually cut a piece out and weld it back in. Most other ford stuff have bolt in plates even the obs. but not the sds
post #8 of 40 (permalink) Old 01-29-2010, 12:51 PM
Custom Trailer Sales
TrailerHauler's Avatar
Theres a writup by "big_stroker" in the transmission section of the forum.
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #9 of 40 (permalink) Old 01-29-2010, 03:04 PM
The Fireman
big_stroker's Avatar
I did it and I love it.
Here is my write up on it.
Auto to Manual Converstion - Powerstroke Nation
big_stroker is offline
post #10 of 40 (permalink) Old 01-29-2010, 05:58 PM
I did a six speed to auto swap about two years ago. The stick was great for towing, but I swapped thinking my wife would drive my truck if she needed to. The thing is, now I don't want her to. Is it just my wife, or do most women go from reverse at 5mph straight to drive? She didn't understand why her tranny took a dump.
I still have all of the six speed stuff if you need any thing.
99 F350 CCLB
skav is offline
