E40D problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 01-26-2010, 07:07 PM Thread Starter
Stroker
Kaleb's Avatar
Send a message via MSN to Kaleb
E40D problems
CaptZach called me earlier, and wanted me to make this post just to be sure that the tranny is in need of a rebuild.
He said he was headed to work and it hung in first for a really long time and when it hit second it shifted extremely hard and the OD light started flashing.
Kaleb
2001 Reg Cab LB-Intake, Exhaust,3in1 gauge, appearance mods
Looking for-99-04 Wrecked Lightning, or 99-04 Mustang GT
Kaleb is offline
post #2 of 8 (permalink) Old 01-27-2010, 04:20 AM
Re: E40D problems
When mine did the same thing it wasnt long after that I had no gears at all.
countryboyrob is offline
post #3 of 8 (permalink) Old 01-27-2010, 04:25 AM
Demon Dually
speeddemon31176's Avatar
Re: E40D problems
Could be debris in the fluid caused the valvebody to stick or a solenoid to stick or might even be bad solenoid pack. could also be a bad tranny. If the O/D light is flashing have the truck scanned for codes and see what happened. It could be any number of things.
speeddemon31176 is offline
post #4 of 8 (permalink) Old 01-27-2010, 06:11 PM
aklim's Avatar
Re: E40D problems
Being that this is an 01, I am thinking it sounds a lot like the diode
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #5 of 8 (permalink) Old 01-27-2010, 09:36 PM Thread Starter
Stroker
Kaleb's Avatar
Re: E40D problems
I guess I should of been more clear, It is another members truck, and its a 96.
Kaleb is offline
post #6 of 8 (permalink) Old 02-04-2010, 02:09 PM
Free mod money?
pwrhungry's Avatar
Re: E40D problems
mine did the samething it was the 1-2 gear sprag blew up
2005,F-350,CC,DRW,6.0L,FX4,MBRP 4",Edge Insight
1996,F-250,XLT,3.55 Gears,4x4 Off Road, Baby Swamp Injectors, BTS Tranny ("wow" Thanks Brian), SuperDuty trans cooler, 6 pos TS Chip ,TYMAR Intake,IssPro Pyro, Boost, Tranny Guages, Bilsein Shocks on all corners, Reflexxion Cowl Hood, 305/70R/16 BFG A/T's
pwrhungry is offline
post #7 of 8 (permalink) Old 02-04-2010, 04:44 PM
Transmission Junkie
Re: E40D problems
Yeah, the transmission is in need of repair. Without having the truck in front of you its hard to pinpoint exactly what it is, but of the two or three things that it can be. None of them are going to allow the transmission to live long at all. It could be any of the things that the previous posts say. If it is a valve sticking in the valve body, he could just need to have the valve body replaced, but depending on the milage it could be time for a refresh anyways.
08 F350 CC Dually, SCT Livewire, DPF/DOC Delete Precision Converter and Performance Powertrain transmission
Performance Powertrain Inc.
Specializing in Performance Ford Transmissions
5R110/4R100/TR3650 and more...
(765)716-2291
02Bluestroker is offline
post #8 of 8 (permalink) Old 02-04-2010, 05:05 PM
captzach's Avatar
Re: E40D problems
yeah its my truck, i was headed to work when it went and i called kaleb to post and see if anyone had any ideas but i had a feeling the tranny was gone...she is currently at Unlimited getting a rebuild, shift kit, and billet torque converter...talked to them today and i should be getting her back tomorrow afternoon
captzach is offline
