07 Transmission service - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Mark Kovalsky
post #1 of 6 (permalink) Old 12-26-2016, 02:41 AM Thread Starter
Garage
Getting ready to change fluid and filter on my 07 6.0. Haynes manual says to drain the torque convertor and replace the convertor plug with a new one. Is it necessary to put in a new drain plug or can I reuse the old one? Thanks for any info!
ford4x4guy74 is offline
post #2 of 6 (permalink) Old 12-26-2016, 04:57 AM
CumminsKingRanch's Avatar
Re: 07 Transmission service
The converter doesnt have a drain plug. Id reuse the drain plug if the o ring looks good.
CumminsKingRanch is offline
post #3 of 6 (permalink) Old 12-26-2016, 02:44 PM
Administrator
Zmann's Avatar
Haynes is worthless
Drain and fill is the DIY way
If it looks like it is in bad shape do more than one fluid swap over a few drive cycles .
Or have Ford do the heated exchange
Dont forget the toilet paper filter up front
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #4 of 6 (permalink) Old 12-26-2016, 02:47 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
and if you go the Ford route, check with your dealer to see if they have the heated-fluid machine. an in-town dealership didn't have it last i checked around here, but the rural dealership did (that one does LOTS of diesel work for oil field service trucks)
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #5 of 6 (permalink) Old 12-26-2016, 08:04 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
I'm glad to see that Haynes is consistent. They are ALWAYS wrong or missing critical information. Ford hasn't had a drain plug in the converter since August, 2001.
When the converters did have drain plugs they didn't have o-rings. The drain plug was a standard 1/8" NPT pipe plug.
Originally Posted by Zmann View Post
Haynes is worthless
Absolutely correct.
Heated flush machines are very rare. But the are absolutely required if you are going to flush the trans. Without a heated machine all they do is take your money.
Zmann likes this.
Mark
Mark Kovalsky is offline
post #6 of 6 (permalink) Old 12-30-2016, 08:41 PM
I meant the drain plug on the pan, since obviously the converter doesnt have one.....
2006 F-250 King Ranch 24 Valve Cummins 5R110
