question about transmision swap? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 01-25-2010, 11:28 AM Thread Starter
found a 5 speed auto out of a 05 with 6.0 motor. will that tranny bolt up to my 7.3 which i have a 4 speed auto. if so how much trouble and is it even worth doing. thanks.
du660 is offline
post #2 of 5 (permalink) Old 01-25-2010, 04:08 PM
Sofa King Cool
BMac's Avatar
Send a message via AIM to BMac Send a message via MSN to BMac Send a message via Skype™ to BMac
Re: question about transmision swap?
not worth doing, it'll be a pain to get shifts right etc, stick with your auto and get it built by BTS if it's taking a dump
People Fly Airplanes, Pilot's Fly Helicopters
2002 F350 Extended Cab Shortbed
1977 Early Bronco
BMac is offline
post #3 of 5 (permalink) Old 01-25-2010, 06:25 PM
The Fireman
big_stroker's Avatar
big_stroker is offline
post #4 of 5 (permalink) Old 01-26-2010, 02:06 AM
Custom Trailer Sales
TrailerHauler's Avatar
The 05 tranny out of the 6.0 (5r110) uses a different bellhousing than the tranny behind the 7.3 (4r100), so it won't bolt up. Like Bmac said, build the one you have, not worth the swap.
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #5 of 5 (permalink) Old 01-26-2010, 04:01 PM Thread Starter
thanks guys. i thought it would be a pain.
du660 is offline
