130*-140* tranny in 45*-55* temps - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 01-24-2010, 03:24 PM Thread Starter
First trip I took since the gauge install, and the trans warmed up and stayed around 130*-140*, it was roughly 80-85 degrees above the outside temp, this is not towing or hauling anything, just running 75mph. From what I have read 70* above ambient is optimal, so I figure it would be worse towing, guess I need to invest in a better cooler
2002 F250 CC 4x4
Tommy69Z28 is offline
post #2 of 6 (permalink) Old 01-24-2010, 03:37 PM
Austinj427's Avatar
Re: 130*-140* tranny in 45*-55* temps
You are doing way better then I am. I usually see 100 over.
Austinj427 is offline
post #3 of 6 (permalink) Old 01-24-2010, 07:11 PM
ARMY bound
100 over ambient is normal and nothing to be worried about.
bbbxcursion is offline
post #4 of 6 (permalink) Old 01-24-2010, 07:40 PM
P.F.F.
smokindiesel2's Avatar
, thats about where im at and no problems.
02 F-250 4X4
96 F-250 4X4
smokindiesel2 is offline
post #5 of 6 (permalink) Old 01-24-2010, 07:52 PM
just a welding fool.
Hawker's Avatar
if you're still running your stock cooler, your trans temps should be around your normal engine operating temps, since the stock trans cooler runs through the radiator.
i was always told you shouldn't have drastic temperature differences; everything in the system should be around the same temp, give or take 20 or 30 degrees.
Swamps
Gearhead Tuning
Diesel Innovations
Hawker is offline
post #6 of 6 (permalink) Old 01-25-2010, 12:58 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
No, that's not how that works.
The ATF does go through a cooler in the radiator, but the cooler is on the cool side of the radiator. The coolant around the cooler has already been cooled by the radiator and is A LOT colder than engine operating temperature. Isn't that what the radiator is there for?
The cooler in the radiator will NEVER warm the ATF. I've measured this in ambient temperatures from +115F to -40F and never found a condition where it's even close. The coolant in the cold side of the radiator is ALWAYS colder than the ATF.
Mark Kovalsky is offline
