E4od hole drilled in forward drum cup plug - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 11-06-2016, 07:34 PM Thread Starter
Kentuckydiesel's Avatar
Air testing the transmission and the forward clutch was leaking air. Pulled it back out to find the "leak" is a hole drilled in the little cup plug in the forward drum.
Apparently some do this to increase lubrication, but I know some others remove the plug, tap the hole, and install a set screw because apparently the plug blows out sometimes.
Need to know which it correct so I can put this thing back together.
Thanks,
Phillip
-1995.5 F350 CC, DRW, ZF5-S47, Converted to 4x4, Kingpin D60 front, TS 6pos chip, Baby Swamps, 4" DP, 5" exhaust, tymar intake, custom fuel system.
-1997 F350 CC SRW, Auto, 4x4, Hypermax chip, Hypermax I/C, unknown DP...more to come.
-1984 F250 SC, LB, 4x4, 4sp manual, western plow.
-1995 John Deere 5200 MFWD w/540 loader
Kentuckydiesel is offline
