Can trango and sonnax kits be used together? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 11-05-2016, 10:27 PM Thread Starter
Kentuckydiesel's Avatar
Rebuilding my wife's '97 E4OD. Got a Sonnax zip kit, but as I went to put the parts in the valve body, I noticed extra springs and two holes drilled at the line pressure modulator valve...apparently the previous owner had put a transgo kit in. Will the parts from these two kits work together, or should I leave out the Sonnax valve body parts?
-1995.5 F350 CC, DRW, ZF5-S47, Converted to 4x4, Kingpin D60 front, TS 6pos chip, Baby Swamps, 4" DP, 5" exhaust, tymar intake, custom fuel system.
-1997 F350 CC SRW, Auto, 4x4, Hypermax chip, Hypermax I/C, unknown DP...more to come.
-1984 F250 SC, LB, 4x4, 4sp manual, western plow.
-1995 John Deere 5200 MFWD w/540 loader
Kentuckydiesel is offline
post #2 of 2 (permalink) Old 11-06-2016, 12:42 PM
410customs's Avatar
Re: Can trango and sonnax kits be used together?
Yes you can use them together
However I would really prefer to see you use the Sonnax stuff and stick with their instructions/mods
We have had excellent luck with Sonnax performance rebuilds inside our auto transmissions.
Valve body mods can often be a home brew of different parts from diff suppliers. Sonnax makes quality stuff and the suggested mods made to our valve bodies have worked wonders. I ran into something similar on my last 4r70w rebuild. I had a transgo shift improver kit and the sonnax rebuild stuff...I ended up ditching the transgo stuff as my buddy and I built the valve body together. He is a transmission guru and as we dug into it he educated me on why to choose the sonnax zip kit and rebuild bits over the transgo.....I think we did use one spring from the transgo kit. The end result is what your after, no matter who's parts get you there. We jsut happen to refer sonnax in our Ford auto's and with great results!
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
