zf5 length - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 01-20-2010, 05:56 PM Thread Starter
redneck engineer
olsmokey's Avatar
zf5 length
is the length on a zf5 about the same as and e4od i was wondering because im wanting to swap mine but im worried about shafts min is a 97 ex cab lb 4x4 thanks
97 f-250 hd solid axle cold air 4in dp 3in body lift 4in exhaust rollin on 36 12.50 swampers hopfully have 46's under it this fall
olsmokey is offline
post #2 of 3 (permalink) Old 01-21-2010, 04:40 AM
Re: zf5 length
no the trannys are not same length the zf 5 is about 8 inches shorter i think so front has to be shortened and rear has to be lengthened i'm in the process of doing the same swap
'96 F 250 Ex cab 4x4 zf 5 speed swap super duty front axle conversion baby swamps ts 4 pos chip edge ez afe cold air intake 4 in lift
'00 excursion 4x4 auto traded for 05 F 350 king ranch
bhfarms is offline
post #3 of 3 (permalink) Old 01-21-2010, 04:43 AM Thread Starter
redneck engineer
olsmokey's Avatar
Re: zf5 length
ah damn the luck thanks
olsmokey is offline
