Tranny BYE BYE!? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 01-17-2010, 05:43 PM Thread Starter
99psd-white's Avatar
Tranny BYE BYE!?
I just got done putting new interior bulbs in the dash of my truck and when i was dont i started up my truck to move it. Well it started and put it in reverse and nothing happened. Put it in drive and nothing.... Does that mean tranny went bye bye?
1999 CCLB 4x4
6.5" pro comp lift
37" bfg KM2
18" muzzi hulk wheel
Isspro gauges
6.0L trans cooler
DP tuner
straight pipe
AIS intake
05 front clip
Ladder bars
BDS steering stabilizer with duel Bilstein shocks
UWS tool box
Hide-a-way gooseneck hitch
Built trans
CCV mod
Zoodad mod
Amp steps
99psd-white is offline
post #2 of 12 (permalink) Old 01-17-2010, 10:42 PM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
Re: Tranny BYE BYE!?
sounds like maybe you missed a plugin or something.
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #3 of 12 (permalink) Old 01-17-2010, 11:52 PM Thread Starter
hmm well sometimes it will move.... but just for a second. And i hear a really terrible rattle coming from the front of the trans.
1999 CCLB 4x4
6.5" pro comp lift
37" bfg KM2
Isspro gauges
6.0L trans cooler
DP tuner
straight pipe
AIS intake
05 front clip
Ladder bars
UWS tool box
Built trans
CCV mod
Zoodad mod
Amp steps
post #4 of 12 (permalink) Old 01-20-2010, 12:30 AM
Transmission Junkie
Most likely the torque converter went bad. You should take it to a shop and have them check the converter. If the converter went bad, you need to have the transmission taken apart and cleaned. The metal shavings from the converter get in the valve body and the rest of the transmission and prohibit the transmission from working correctly.
08 F350 CC Dually, SCT Livewire, DPF/DOC Delete Precision Converter and Performance Powertrain transmission
Performance Powertrain Inc.
Specializing in Performance Ford Transmissions
5R110/4R100/TR3650 and more...
(765)716-2291
02Bluestroker is offline
post #5 of 12 (permalink) Old 01-20-2010, 07:33 PM
aklim's Avatar
Have you checked the pan? Drain and keep the fluid. If there is too much debris, put the fluid back.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #6 of 12 (permalink) Old 01-23-2010, 04:23 AM Thread Starter
had it towed to the shop monday morning and finally got it back tonight. They built the crap out of it! 3400 rebuild.
1999 CCLB 4x4
6.5" pro comp lift
37" bfg KM2
Isspro gauges
6.0L trans cooler
DP tuner
straight pipe
AIS intake
05 front clip
Ladder bars
UWS tool box
Built trans
CCV mod
Zoodad mod
Amp steps
post #7 of 12 (permalink) Old 01-23-2010, 04:29 AM
ARMY bound
Almost could of had a BTS for that cost.
bbbxcursion is offline
post #8 of 12 (permalink) Old 01-23-2010, 05:15 AM Thread Starter
yeah after another grand lol plus i needed my truck asap and wouldnt have time to put it in cuz im going to school
1999 CCLB 4x4
6.5" pro comp lift
37" bfg KM2
Isspro gauges
6.0L trans cooler
DP tuner
straight pipe
AIS intake
05 front clip
Ladder bars
UWS tool box
Built trans
CCV mod
Zoodad mod
Amp steps
post #9 of 12 (permalink) Old 01-24-2010, 12:47 AM
00Rich's Avatar
2008 F-250 FX4 cc,4x4
00Rich is offline
post #10 of 12 (permalink) Old 01-24-2010, 01:44 AM Thread Starter
i know i was thinking of going bts but no reason to spend the extra 1000 bucks when I am going to sell my truck in two years.
1999 CCLB 4x4
6.5" pro comp lift
37" bfg KM2
Isspro gauges
6.0L trans cooler
DP tuner
straight pipe
AIS intake
05 front clip
Ladder bars
UWS tool box
Built trans
CCV mod
Zoodad mod
Amp steps
