Old ZF5 loose shifter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 08-30-2016, 02:57 PM Thread Starter
<---F350 DRIFTER
drwoodchopper's Avatar
I swaped out my auto for a ZF last year and have no previous experience with this trans. I had it rebuilt due to worn out syncros. The shifter has always been loose but it is getting worse. It does still have the spring tension in it but is quite weak. The shifter has 3-4" of play in it in every gear in every position. Any one know how to fix this? I am thinking it is the part the stick attaches to because you can easily tell nothing is moving inside of the trans. The trans shift great does not fall out of gear or do anything strange...just has a bunch of play in the stick. The only issue is it makes it a little awkward to downshift because it is so loose.
Thanks.
97
PSD. CC 4X4 195K, IDM mod, 6 Leaker IC, DP Tuner 6pos chip, WOP QSSB Turbo, kit by Carson Stauffer. Swamps 175/146's sticks, CNG kit 35mpg's on the diesel, E-fuel, Adrenaline and converted to a ZF5. RSK rolling on 35's. 4" straight pipe. 2011 f350 ccsb leveled on 35's, I can neither confirm nor deny that it is tuned and deleted!
drwoodchopper is offline
post #2 of 3 (permalink) Old 09-01-2016, 12:25 PM
410customs's Avatar
Re: Old ZF5 loose shifter
shifter rebuild kit?
The whole thing rides inside two nylon bushings
I used this kit when I installed my rebuilt zf5, nice and tight shifter, easy to find the gears
410customs is offline
post #3 of 3 (permalink) Old 09-02-2016, 04:30 PM Thread Starter
<---F350 DRIFTER
Thanks. I ordered that and the pivot bushing. Hope that fixes it up!
97
