2001 F-25 wont engage park - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 08-11-2016, 11:15 PM Thread Starter
Goneracin's Avatar
Send a message via AIM to Goneracin
It started months ago where I would have to wiggle the shifter while turning the key before it would start. Now my remote start wont work because the truck doesnt think its in park. And today, the truck actually started to roll and you could hear park trying to engage.
There must be an adjustment somewhere, but I cant find it. The transmission works and shifts fine, it must be a linkage issue.
Please help
2001 F-250 7.3L auto
Suspension stuff, engine stuff, reliability stuff...
Some other stuff I'm forgetting...
Goneracin is offline
post #2 of 5 (permalink) Old 08-12-2016, 11:31 AM
alleged moderator
tjctransport's Avatar
Re: 2001 F-25 wont engage park
under the dash on the back of the steering column, there are two torx screws that connect the shift cable to the shift tube. they loosen up.
if those screws are tight, then you will need to adjust the cable under the truck at the shift arm on the trans.
tom
tjctransport is offline
post #3 of 5 (permalink) Old 08-12-2016, 11:47 AM Thread Starter
Goneracin's Avatar
That sounds like it could be it. By back of steering column, do you mean it is on the column, between the column and the dash, or is it facing towards the floor?
Thanks for the help
post #4 of 5 (permalink) Old 08-12-2016, 11:53 AM
wackyman9's Avatar
Just had his happen on the 05 work truck... The spring on the parking pawl was shot. It's a teeny little "L" that engages when in park. The spring failed and it rolled a couple times and then finally ended wiggling into the trans on the expressway and wound up shearing the driveshaft where it meets the transmission on the output shaft.
-2008 Job #3 F250 CCSB 4x4
-Mishimoto Aluminum Radiator
-Peak Fleet Charge Purple Coolant
-SCT X4 Babysitter
-17" XD Addicts
-285 General Grabber AT2's
-Power Service White in the Tank
-Moog Tie Rods and Drag Arm
-Drilled and Slotted Rotors
-GearBoxZ DPF-R 4.0
-Flo-Pro DOC/DPF delete
-MPD CCV Kit
-Injen Evo CAI
wackyman9 is offline
post #5 of 5 (permalink) Old 08-12-2016, 07:18 PM
alleged moderator
up under the back of the dash at the end of the shift tube is the only way i can explain it. you have to get down on the floor with your head around the brake pedal to look up and see it. a flashlight helps too.
tom
