Tranny swap? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 08-11-2016, 10:47 PM Thread Starter
1999 Flatbed's Avatar
Garage
Tranny swap?
I have a 99 F350 with 7.3. It scrubs bad shifting into 3rd and nothing in 4th. Feels like it's in neutral. I've got a 88 f350 7.3 parts truck, but was wondering if the 5 speed zf would be interchangeable with 99. I know ratio is different, and not as strong, but would it swap out? Thanks for any help.
1999 Flatbed is offline
post #2 of 9 (permalink) Old 08-12-2016, 12:25 AM
79jasper's Avatar
Re: Tranny swap?
Should swap.
I have a zf from a 88 in my 94.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #3 of 9 (permalink) Old 08-12-2016, 11:29 AM
alleged moderator
tjctransport's Avatar
Re: Tranny swap?
the 99 was offered with the ZF5 speed.
tom
tjctransport is offline
post #4 of 9 (permalink) Old 08-12-2016, 02:10 PM
Moderator
Sbluke55's Avatar
Re: Tranny swap?
I thought only the E99 had the zf5 while the L99 had the zf6.
01 f-250, Standard
Sbluke55 is offline
post #5 of 9 (permalink) Old 08-12-2016, 07:14 PM
Schneider 86's Avatar
Re: Tranny swap?
Not sure when they switched to the zf6, but I would think it would bolt right up. Of course there would be a couple minor issues. 1) your cross-member might not work 2) the driveshaft might not be the correct length or u-joint 3) not sure about the zf6 slave cylinder, it might be different don't know. Regardless, I would check all of the above. Also the zf6 had a "cooler" attached to it I believe, so you're going to have a couple cooler lines hanging with no where to go (I suppose you could remove it all together.....).
Schneider 86 is offline
post #6 of 9 (permalink) Old 08-12-2016, 07:26 PM Thread Starter
Garage
Re: Tranny swap?
Thanks for all the support. I was for sure it would bolt right up, but any help on clutch, pp, throw out bearing, fork arm comparability would be greatly appreciated.
post #7 of 9 (permalink) Old 08-12-2016, 07:39 PM
79jasper's Avatar
Re: Tranny swap?
If zf5 to zf5, it's all the same.
79jasper is offline
post #8 of 9 (permalink) Old 08-14-2016, 03:56 PM Thread Starter
Garage
Re: Tranny swap?
Please help with which year model would I purchase clutch kit for? Tranny year(88)? Or engine year (99)? Thanks.
post #9 of 9 (permalink) Old 08-14-2016, 07:19 PM
79jasper's Avatar
Re: Tranny swap?
Obviously engine year.
79jasper is offline
