What transmission cooler are you running on your E4OD? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 08-01-2016, 12:56 AM Thread Starter
I'm looking to upgrade the from the dinky-ass stock transmission cooler on my '97, and I am curious to see/hear about what cooler setup you guys are running on your trucks, and how well they're working for you. There's a lot of options out there, and I'd just like to hear your all's opinions.
1997 F-250 SCFB, 4X4, E4OD 341,000 all stock miles.
RustyBolts is offline
post #2 of 8 (permalink) Old 08-01-2016, 03:17 AM
Moderator
Sbluke55's Avatar
Re: What transmission cooler are you running on your E4OD?
6.0 trans cooler. Then upgrade to superduty trans lines. More flow and you will run cooler.
01 f-250, Standard
Sbluke55 is offline
post #3 of 8 (permalink) Old 08-01-2016, 03:24 AM Thread Starter
Do the SD lines need modified (length/bends) in any way to work on an OBS?
post #4 of 8 (permalink) Old 08-02-2016, 11:27 PM
dadada's Avatar
Just use rubber transmission lines.
dadada is offline
post #5 of 8 (permalink) Old 08-05-2016, 11:08 PM Thread Starter
So, I might've had an epiphany today... Happened to be around one of our parts tractor today, and it's hydraulic cooler caught my eye...
...has a 5/8" inlet and outlet (which I'd have to adapt to, but that's no big deal) it has 2 rows of wide, flat cores in it, and a fairly size-able top and bottom set of tanks on it. More fluid capacity, lots of cooling surface, and it's free! ;-) now if itll fit between my radiator and bumper, we'll be aces!
Whatcha think??? Any holes in my theory???
post #6 of 8 (permalink) Old 08-06-2016, 01:36 AM
Moderator
Sbluke55's Avatar
Looks like it will work.
01 f-250, Standard
Sbluke55 is offline
post #7 of 8 (permalink) Old 08-12-2016, 03:49 AM
CumminsKingRanch's Avatar
6.0 cooler will do way better I would think.
2006 F-250 King Ranch 24 Valve Cummins 5R110
CumminsKingRanch is offline
post #8 of 8 (permalink) Old 08-13-2016, 02:47 PM
I just installed a TruCool 4739 and it did the trick. It's a very easy install and is very effective. My former 220F temps towing were reduced to the 160F range towing.
While I didn't have any problems running at 220F, I decided to spend a few bucks to see if maybe running a cooler temp would help. Don't know if it will make the tranny live longer, but the temps are sure down.
Airstreamer67 is offline
