need help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 01-05-2010, 03:00 AM Thread Starter
need help
well im having trouble with my truck it seems when I put it in reverse that it just shuts off like the rpms drop and then it dies. I have had the valve body and converter replaced because that's what the trans shop we took it to said would fix it but didn't and ford has bin no help at all saying they cant figure it out so im wondering if any of yall have any ideas on what could be the problem.
Thanks guys
2001 7.3l f350 cc 8inch icon lift 37in toyos
mbrp 4in exhaust ,afe stage 2 intake,dp tuner,guages,
soon to come mods-bts vb, itp ss line,ats turbo housing and then bts trans
powerking3300 is offline
post #2 of 9 (permalink) Old 01-05-2010, 03:33 AM
Re: need help
Don't know if it is the problem. But I took a class from Mike Cleary and he talked about the IPR doing something like this on occasion.
There is a nut on the back that could come loose. And when in reverse it shuts the truck off.
1997 F350 7.3L OBS (Old Big and Slow)
3" Downpipe (cat delete 364.5 days a year)
Custom tunes by ME
AFE Intake
Rebuilt Transmission(The works-Tripple disk TQ, All Steel insides)
Old Big and Slow is offline
post #3 of 9 (permalink) Old 01-05-2010, 03:45 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Re: need help
You say valve body. Do you mean solenoid pack?
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #4 of 9 (permalink) Old 01-05-2010, 04:06 AM Thread Starter
Re: need help
where is the ipr? and is the bolt something i can just tighten myself?
and no it was the valve body that was replaced.
thanks
post #5 of 9 (permalink) Old 01-05-2010, 04:08 AM
Metal - It kicks your ass
Re: need help
Would the TC locking up pre-maturely cause this.??
Modded L99
dirtboy25 is offline
post #6 of 9 (permalink) Old 01-05-2010, 04:10 AM
redneck engineer
olsmokey's Avatar
Re: need help
mine did that cuz it was low on fluid
97 f-250 hd solid axle cold air 4in dp 3in body lift 4in exhaust rollin on 36 12.50 swampers hopfully have 46's under it this fall
olsmokey is offline
post #7 of 9 (permalink) Old 01-05-2010, 11:01 PM
Stone Crusher
trackspeeder's Avatar
Re: need help
Yes.
Low fluid or internal problems will cause that.
01 F250 XLT 4X4 Auto trans, Dark Highland Green, Green fuzzy dice,Di Pricol Optix gauges,Dura Lite air cleaner,CCV mod,coolant filter,,AIC,XM Satilite radio.
trackspeeder is offline
post #8 of 9 (permalink) Old 01-06-2010, 12:22 AM
Fixing Broken Stuff
toolmangary's Avatar
Re: need help
pressure is leaking in to the lock up circuit from another circuit, probably in the pump. been there before
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #9 of 9 (permalink) Old 01-06-2010, 01:46 AM
02 CCSB
Re: need help
Another vote for the pump-an internal hydrualic leak to convertor apply circuit. Replace with a NEW not reman pump, this problem starts showing up in reverse because line pressure is significantly higher than in other gears and you aren't moving.
02 CCSB is offline
