think my trans blew up 6speed now maybe? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 01-03-2010, 02:21 AM Thread Starter
so i was driving down the street the other day accelerating not flooring it or anything but all of a sudden it made a loud boom and now every gear is like neutral any suggestions?
big black is offline
post #2 of 15 (permalink) Old 01-03-2010, 02:38 AM
King Dingaling
TANK'S 250's Avatar
Re: think my trans blew up 6speed now maybe?
I have a Zf6 out of an 05, and a transfer case if you're looking for one.
TANK'S 250 is offline
post #3 of 15 (permalink) Old 01-03-2010, 05:07 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
And what transmission do you have?
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #4 of 15 (permalink) Old 01-03-2010, 06:02 AM
That thing got a Cummins?
nasty96's Avatar
Sounds like an input shaft may have broke. I don't know if they can be replaced as easly as the nv4500 in the dodges. Time to drop the trans. Good Luck
Ford makes it
, I break it
1996 F350 CCLB 4x4 Broke Built Auto
2000 Dodge 3500 5 Speed 4x4 450k and Counting
2001 Dodge 3500 6 speed 4x4 Fully loaded
nasty96 is offline
post #5 of 15 (permalink) Old 01-03-2010, 06:33 AM Thread Starter
i have an 01 will an 05 6speed work? input shaft? i was thinkin either that or the convertor but i really dont know about trans thanks for the input guys
post #6 of 15 (permalink) Old 01-03-2010, 02:09 PM
nasty96's Avatar
Sorry, thought you had a manual. Tell us what you find. Good luck
Ford makes it
, I break it
nasty96 is offline
post #7 of 15 (permalink) Old 01-03-2010, 02:34 PM
Jeremy's Avatar
You probably broke the flex plate. It not uncommon for that to happen, and cheap in the grand scheem of things to fix.
Jeremy is offline
post #8 of 15 (permalink) Old 01-03-2010, 06:31 PM Thread Starter
it still starts and runns tho
post #9 of 15 (permalink) Old 01-03-2010, 06:57 PM
oilfield trucker
zpilgeram's Avatar
Do you have a 4x4 ? If so you may have had a shifting fork go bad in your transfer case. Try putting your truck in low range and see if anything happens.
96cc,lb,4x4,zf5. DIY dual filter intake, intercooled,gauges,4''down pipe, DIY front bumper/grill guard,fuel tank mod, 238cc Rosewood Diesel hybrids,6pos chip from TDP,
stealth SRP1 HPOP,Garrett GT4294 with DIY mounting kit,valair 500hp kevlar/ceramic clutch,Dual SD pumps electric fuel system with regulated return,5'' DIY Straight pipe.
zpilgeram is offline
post #10 of 15 (permalink) Old 01-03-2010, 07:57 PM
No, different bell housings.
1999 F350 6SPD 4x4 LARIAT Tymar, DP-F5, ITP Reg Return, 4" Exhaust **SOLD**
2002 F350 REG CAB DRW 2WD Tymar, PHP, 5" stack, DJM drop hangers and shackles, Hellwig sway bars, Nathan K5LA, Full Power '08 Mirrors...**SOLD**
DIRTBIKEZ is offline
