97 powerstroke transmission trouble shifting into forward gears - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-10-2016, 01:50 PM Thread Starter
techteacher's Avatar
My buddy is having issues with his 97 auto trans. Sometimes it will go right into gear other times it takes 20 min to get in gear. It won't go into any forward gear or drive. Any idea from reading the other threads I am thinking maybe the solenoid.
techteacher is offline
post #2 of 4 (permalink) Old 06-11-2016, 12:54 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 97 powerstroke transmission trouble shifting into forward gears
"The" solenoid? There are four in the transmission. Which one do you mean? None of them control engagements.
If reverse works normally and no forward gear does, I suspect a bad seal in the forward clutch. That means the transmission needs to be rebuilt.
Mark
Mark Kovalsky is offline
post #3 of 4 (permalink) Old 06-11-2016, 06:48 PM Thread Starter
Thanks for the reply. I was hoping it didn't need a rebuild but I guess it's probably needing one.
post #4 of 4 (permalink) Old 07-27-2016, 12:39 AM
Take it from experience, if it takes a while for it to engage D, 2, or 1, you've got a mechanical issue related to the Forward Clutch that no amount of new fluid, solenoid packs, or even prayer will resolve. Gonna need rebuilt :-/
1997 F-250 SCFB, 4X4, E4OD 341,000 all stock miles.
RustyBolts is offline
