5R110 cooler flow test and line psi - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 06-02-2016, 09:52 PM Thread Starter
Administrator
Zmann's Avatar
so I am replacing my Tranny with a reman from Ford
I bought a new OTA cooler but have to flush back flush the
OTC radiator cooler due to debris
once I am done i will be installing a filter at the return line just before it enters the trans
but I want to check the flow can i use the same method our favorite former
Ford Engineer describes for the 4R100
There needs to be a minimum of one gallon per minute through the cooling circuit. The way to test this is with a helper and two containers. Remove the line at the rear of the trans and aim it into the first container. Have your helper start the engine. Once the flow is solid move the line to the second container for exactly 15 seconds the put it back in the first container. Shut the engine off. If there is at least a quart in the second container there is enough flow. I'd do this with the new cooler installed to make sure it works. If there is fluid spraying out of the transmission when you do this it fails regardless of how much flow you get.
__________________
Mark K
any idea what the psi is at the fluid is at to the cooler circuit when this test is done ?
I may want to check before i have the tranny in
and I will be checking line psi at the test port after install
Range idle stall
P/N 50 ----
R 100 320
D 70 320
3 80 260
2 80 215
1 80 270
thanks
Z
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #2 of 10 (permalink) Old 06-03-2016, 12:37 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 5R110 cooler flow test and line psi
That test won't work for a 5R110. The flow rate with the trans below 170F is 10% of the flow rate above 170F. How would you know if the thermostat opened or closed while the test is running? And I don't have the flow rate for the 5R110. Below 170F it's going to be less than the 4R100, above 170F it's going to be quite a bit higher. But I don't have actual numbers.
Checking line pressure is good, checking cooler circuit pressure doesn't have much meaning.
Mark
The good thing about science is that it's true whether or not you believe in it. ― Neil deGrasse Tyson
Mark Kovalsky is offline
post #3 of 10 (permalink) Old 06-03-2016, 12:47 AM Thread Starter
Administrator
Zmann's Avatar
thanks Mark
I found some details in the OEM manuals
really the only reason I care about the flow rate is it is an OEM requirement
for their remanufactured transmissions
and really the only part in question is the lower cooler since I did not replace it
2005 5r110
Remove the fluid level indicator from the fluid filler tube.
Place a funnel in the fluid filler tube.
Raise and support the vehicle.
Disconnect the cooler return tube (rear fitting) from the transmission case.
Install a suitable plug into the rear case fitting.
Connect one end of a hose to the cooler return tube and route the other end of the hose up to a point where it can be inserted into the funnel at the fluid filler tube.
Remove the supports and lower the vehicle.
Insert the end of a hose into the funnel.
Start the engine and run at idle with the transmission in the NEUTRAL range.
Once a steady flow of fluid (without air bubbles) is observed, remove the hose from the funnel and place the hose in a measuring container for 15 seconds. After 15 seconds, place the hose back into the funnel and turn the engine off. Measure the amount of fluid in the container.
Temperature Flow
44C (112F) 236.6 ml (8 oz) 15 sec
78C (172F) 473.2 ml (16 oz) 15 sec
82C (180F) and up 1893 ml (64 oz) 15 sec
There is a temperature valve in the pump. Cooler flow rates will vary according to automatic transmission fluid temperature. The use of a diagnostic tool will determine the actual fluid temperature. If adequate flow is observed into the container, the test is now complete
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #4 of 10 (permalink) Old 06-03-2016, 12:50 AM Thread Starter
Administrator
Zmann's Avatar
the line pressure stall test has a interesting procedure I am sure I missed something like drive line removal ? still reading up on that one since it's 110* outside I don't have anything better to do
place blocks at wheels
D 1 2 3 to WOT Wide Open Throttle AKA stall psi
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 10 (permalink) Old 07-20-2016, 02:07 PM
Is the gallon per minute spec applicable to the OBS 7.3 E4OD?
1996 F250 CCSB, 4x4, auto PSD, stainless window vents.
Signature file limitations keep me from sharing more information. Follow this link to find my threads: D60 RSK install, Air vent cleaning, etc.
leojr is offline
post #6 of 10 (permalink) Old 07-20-2016, 08:52 PM
The E4OD spec is one gallon per minute according to my memory.
Mark
post #7 of 10 (permalink) Old 07-21-2016, 12:34 PM
Thanks!
I have a 13 row trans cooler from a SD (maybe a van?) and also a similar sized 4739 TruCool that I am considering installing in series but want to verify that I did not add too much restriction.
leojr is offline
post #8 of 10 (permalink) Old 07-21-2016, 12:59 PM
You'll have too much restriction. That's not a good idea. If you insist on two coolers, make them in parallel. That's not as bad as in series.
Mark
post #9 of 10 (permalink) Old 07-21-2016, 03:22 PM
Understood.
The choice of the word "insist" makes me believe that either cooler may be sufficient and the two are not necessary?
leojr is offline
post #10 of 10 (permalink) Old 07-22-2016, 02:05 AM
Two have the possibility of cooling less than one cooler. If there is enough restriction with two coolers in series the cooler bypass will open and the fluid will not go to the coolers.
If you want to improve your cooling replace the cooler you have with a cooler from a 6.0L F-Series.
Mark
