No start after manual Trans Cummins swap. 05 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 05-18-2016, 02:38 PM Thread Starter
I know this is been talked about in lots of different threads . I think I've read them all. I'm doing a 24 valve with a 10 speed swap in my automatic 05. I don't care about manual tuning in my PCM because my PCM does not control the motor. I also don't care about a manual transmission harness because there's nowhere to plug it into on the 10 speed. Does anybody know how to bypass the park neutral safety switch wiring? I have found on a wiring schematic that there are three wires pink/white black/ white and a light blue/yellow. Just not sure how to trick the PCM into thinking it's in park. Also if the pCM stays auto then I shouldn't have to worry about the clutch pedal position switch also, correct?
Yeats5.0 is offline
