tranny finished? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 12-31-2009, 03:46 PM Thread Starter
crawlake's Avatar
tranny finished?
Hi, I have a 2001 7.3. It has about 80,000 miles on it. A couple days ago the truck wouldn't shift from 1st to 2nd unless I let right off. It did shift once at about 3000rpm, but shifted really hard, then the od light started flashing. The transmission fluid is a bit dark, and smells a little burnt. I took it to the local trans shop, they said the codes were 1st to 2nd shift, and 2nd to 3rd shift. They didn't give me any numbers. They also said that the tranny is toast, what do you guys think? Nothing slips, and it all happened suddenly.
crawlake is offline
post #2 of 6 (permalink) Old 12-31-2009, 04:13 PM
Work in progress
opieg01's Avatar
Re: tranny finished?
Sounds like a typical 01 diode failure. Time for a rebuild sorry man
2001 F-250 4X4 LARIAT Crew Cab,7.3, ZF6
GTX-4294r, Swamps 300/200%
couple other bolt ons
opieg01 is offline
post #3 of 6 (permalink) Old 12-31-2009, 05:13 PM
GRT
GRT is offline
post #4 of 6 (permalink) Old 12-31-2009, 05:30 PM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
When the shifts didn't happen, the transmission probably upped the line pressure to make it happen. Which is your resulting harsh shift. Keep that up and it will tear itself apart. Get it looked at before the cost goes up.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #5 of 6 (permalink) Old 12-31-2009, 05:46 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
They're right. The mechanical diode failed. The trans has to be rebuilt or replaced. Further driving will just make the rebuild more expensive.
Mark Kovalsky is offline
post #6 of 6 (permalink) Old 12-31-2009, 06:46 PM Thread Starter
crawlake's Avatar
Thanks guys. Does anybody happen to know of a good place to get a transmission rebuilt up here in Alberta, Canada? Or if there is a BTS dealer up this way somewhere?
crawlake is offline
