Transmission Seal Failure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 12-29-2009, 08:01 AM Thread Starter
Underfunded
moonshiner's Avatar
Send a message via AIM to moonshiner
Tranny has a leak somewhere to the rear of the transmission pan, and Im unable to pinpoint it with all the dirt, any ideas what to replace, or what to reseal? possible schematic?
Thanks
1996 F350: 4.10's Detroit Locked Front/Rear, Rampage Chip, SD/Racor E-Fuel, Adrenaline, 160cc's, Bell SS/66 Turbo, SD CAC, 315/75/16's Fierce M/Ts, 6" Lift, 6ft Traction Bars, 5" Stacks.
2007 Harley FXSTB: Bassani Prostreet Pipes, Terry Comp tuner, V&H Air Cleaner
2008 Honda Ridgeline RTX
2010 VW Jetta 2.5
SEMPER FI - USMC LT.
moonshiner is offline
post #2 of 8 (permalink) Old 12-29-2009, 06:09 PM
gnxtc2's Avatar
Re: Transmission Seal Failure
I would check the two piece dipstick tube. Check the portion that enters the trans. Mine was leaking there and running towards the back of the trans. Took it apart, cleaned everything with brake cleaner, let it dry and sealed the tube with gray Int'l RTV. Everything it dry so far.
Billy T.
[email protected]
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
post #3 of 8 (permalink) Old 12-29-2009, 07:50 PM
Jeepermc's Avatar
Think with your dipstick Jimmy!.... And get a pressure washer. Go from there.
1997 F-350 PSD. Std Cab. Auto. IDM Mod, 1's,17* HPOP, TS-6 pos. tweaked by TW. ARB Bull bar, 8,000# Warn, IPF lights, 315/75/16 Toyo mud terrain.
Jeepermc is offline
post #4 of 8 (permalink) Old 12-30-2009, 01:10 AM
tbolt's Avatar
I would definately clean it good and see where it's leaking before throwing parts at it.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #5 of 8 (permalink) Old 12-30-2009, 02:15 AM Thread Starter
Underfunded
moonshiner's Avatar
have pressure washer, unfourtunatly ive had bad luck with using it to wash the truck with, killed my Valve cover harness's once,
I did however pick up 10 cans of brake cleaner....
2010 VW Jetta 2.5
post #6 of 8 (permalink) Old 12-30-2009, 02:22 AM
tbolt's Avatar
Use brakeclean or something and just don't get so close with the power washer.
Glen
tbolt is offline
post #7 of 8 (permalink) Old 12-30-2009, 06:49 PM
Jeepermc's Avatar
Yeah...pressure washing the motor isn't recommended...But it's your transmission that is dirty...and leaking.....remember?
Jeepermc is offline
post #8 of 8 (permalink) Old 01-01-2010, 07:51 PM Thread Starter
Underfunded
moonshiner's Avatar
turns out the bolts on the outside holding the transfer case to the rear of the tranny managed to vibrate out... so tomorrow they will all get replaced.
2010 VW Jetta 2.5
