zf5 grinding gears - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 04-13-2016, 02:12 AM Thread Starter
<---F350 DRIFTER
drwoodchopper's Avatar
zf5 grinding gears
A few months ago I swapped from auto to a s47 zf5. The zf had 300k on it and has been grinding from the 2-3 up shift and the 3-4 down and 3-2 down since I installed it. I have put 7k miles on it like this being carful to shift real slow on the 2-3 and 4-3 but it is basically impossible to shift into 2nd over 5mph. Before I drop a bunch of cash on a reman is there anything to check like clutch master/slave to make sure it is all working proper? Everything feels good to me. I put in a new pre bled master/slave cylinder when I did the swap. I am thinking about rebuilding myself if you think new syncros, bearings, rings, ect is all it needs. How hard of job is it? Special tools needed?
Thanks
97
PSD. CC 4X4 195K, IDM mod, 6 Leaker IC, DP Tuner 6pos chip, WOP QSSB Turbo, kit by Carson Stauffer. Swamps 175/146's sticks, CNG kit 35mpg's on the diesel, E-fuel, Adrenaline and converted to a ZF5. RSK rolling on 35's. 4" straight pipe. 2011 f350 ccsb leveled on 35's, I can neither confirm nor deny that it is tuned and deleted!
drwoodchopper is offline
post #2 of 11 (permalink) Old 04-13-2016, 02:44 AM
79jasper's Avatar
Re: zf5 grinding gears
Sounds like the sychros are just bad.
You could try changing the fluid, but no guarantees.
Also when you downshift, Rev the engine a little.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #3 of 11 (permalink) Old 04-13-2016, 02:47 AM
Moderator
Sbluke55's Avatar
Do you have trouble getting it in 1st or reverse? What brand master?
01 f-250, Standard
Sbluke55 is offline
post #4 of 11 (permalink) Old 04-13-2016, 03:13 AM Thread Starter
<---F350 DRIFTER
I put new fluid in it from the start and has done it from the start of the swap. Tried the revving and it doesn't help either.
No, seems fine but I am always stopped. It smoothly goes into all gears when stopped. Dorman brand.
Should I try bleeding it? It feels good....atleast I think it does.
97
post #5 of 11 (permalink) Old 04-13-2016, 03:44 AM
Moderator
Sbluke55's Avatar
I know in the superduty the Dorman master cylinder rod is shorter than the oem rod.
Is there any play in the pedal bushings?
I just want to eliminate a disengagement issue before you drop money on a rebuild.
01 f-250, Standard
Sbluke55 is offline
post #6 of 11 (permalink) Old 04-13-2016, 03:50 AM Thread Starter
<---F350 DRIFTER
Not much play. I actually adjusted the arm foreward to push the rod a little further to see if that helped....it didn't. I can adjust it further but then my cruise will not work. Also before I installed it the rod appeared to be the same as the stock one..
97
post #7 of 11 (permalink) Old 04-13-2016, 07:06 PM
My ZF5 grinds from time to time. Has been for a couple of years. Run the correct synthetic oil it will help if you are not. I also overfill the ZF5 which also helped take care of the gear rollover a bit along with reducing the grinding shifts a little. It usually only happens when I am flying thru the gears and when cold.
97 250 7.3 Eaton VMP TVS, IDI performance T4 mount, S369SXE, my B code 350/200- my tunes- honey badger SR, Efuel, 5" SKY RSK TTB, BMW M3 seats, Toyo M/T
54 GMC 453T
45 Chevy 451 diesel
51 Mack A51T
1916 Federal 1 1/2T
boostedretard is offline
post #8 of 11 (permalink) Old 04-13-2016, 07:47 PM Thread Starter
<---F350 DRIFTER
Originally Posted by boostedretard View Post
My ZF5 grinds from time to time. Has been for a couple of yesxars. Run the correct synthetic oil it will help if you are not. I also overfill the ZF5 which also helped take care of the gear rollover a bit along with reducing the grinding shifts a little. It usually only happens when I am flying thru the gears and when cold.
I have the right fluid and mine does it worse when warm as the fluid warms up.
97
post #9 of 11 (permalink) Old 04-13-2016, 10:36 PM
Also check the throw on your fork. My original fork was warped after putting a new one in the throw was about half as much. The original forks had tsb for being weak if I recall and the new fork was an updated one. I think. From the dealership the price was not that bad.
54 GMC 453T
45 Chevy 451 diesel
51 Mack A51T
1916 Federal 1 1/2T
post #10 of 11 (permalink) Old 04-13-2016, 11:00 PM Thread Starter
<---F350 DRIFTER
I put a new fork in when I installed it but I will check it. Thanks
I called a local diesel shop and he quoted me $800 to rebuild it with new syncros, bearings, ect so I am going to do that. Before I even told him what it was doing he said "let me guess, 2nd and 3rd are grinding."
Trans shops wanted $1700- $2000 for a reman unit.
97
