HELP!!!LOCK UP DROPS IN/OUT - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 12-26-2009, 02:22 AM Thread Starter
Unhappy HELP!!!LOCK UP DROPS IN/OUT
MY '95 F350 WILL SHIFT FINE ALL THE WAY TO OD. THEN WHILE CRUSING ABOUT 55-60MPH I CAN FEEL THE TC DROP PUT AND THE TACH RISES ABOUT 500RPM'S.IF I PRESS ON THE PEDAL A LITTLE YOU CAN FEEL IT LOCK UP AGAIN LET OFF A LITTLE AND IT UNLOCKS. THE OD LIGHT NEVER BLINKS AND THERE ARE NO CODES.
FNMINA is offline
post #2 of 7 (permalink) Old 12-26-2009, 03:32 PM
Re: HELP!!!LOCK UP DROPS IN/OUT
Check your lamps, or did you swap LEDs recently. The PCM reads voltage throught the brake lamp circuit for TC lockup. Has your ABS light came on?
timfinnegan is offline
post #3 of 7 (permalink) Old 12-26-2009, 11:38 PM Thread Starter
I do have LEDs in the rear! No ABS light. Should I install an isolation relay in the brake light circut?
FNMINA is offline
post #4 of 7 (permalink) Old 12-30-2009, 03:53 AM
Either that or a resistor. If you can find the package that the lamps came in it will tell you what to do to fix the problem.
post #5 of 7 (permalink) Old 12-30-2009, 04:33 AM
FordCowboy's Avatar
Or it could just be that your TC is locking and unlocking and taking a dump. Mine was doing that with no codes or anything. Then before the TC was able to completely quit my clutches burned up, seems like the TC can often times start to go then cause other weak components to fail before it does.
Early 99 Powerstroke
Crew Cab Short Bed Lariat 4x4
SCT Livewire w/ various custom tunes
Adrenaline
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
Automatic trans: PI Converter, tugger kit
Leveling Kit w/ 35's
FordCowboy is offline
post #6 of 7 (permalink) Old 12-30-2009, 04:43 AM
06powerstroke's Avatar
Checking the LED's is worth a try, but running LED's usually cause the torque converter to stay locked when on the brakes, not go back and forth...
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
06powerstroke is offline
post #7 of 7 (permalink) Old 12-30-2009, 02:41 PM
01platinum's Avatar
Do you have chip or programmer on there? If you do pull it for a day and drive it then put it back in.
My truck did that one day out of the blue. I pulled the chip put it back in and no problems.
Real Diesels Have Stacks
New Tunes by Matt @ Gear Head - Auto Meter Gauges from Nate @ PTP
Air Dog II Fuel Pump
First RR Fuel System built by hand @ Murff Racing
More to come soon..........
01platinum is offline
