intermittent shifting Problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 03-09-2016, 03:09 AM Thread Starter
I recently had my injector harness replaced. Not sure whether it has
anything to do with this but now at speeds of 40 thru 65 my trans likes to intermittently shift from 4th to third. Back and forth it goes. One trans shop says I need to rebuilt my trans another shop says there
is nothing wrong however, they pulled a code 0500 (open circuit) which has to do with the VSS (sensor or wiring). I took it to another shop and they said its my valve body in the transmission that causes shifting issues. I wonder if I would be better off just having the trans
rebuilt. Any thoughts?
Egster55 is offline
post #2 of 2 (permalink) Old 03-09-2016, 02:45 PM
old Smokey's Avatar
Re: intermittent shifting Problems
What year truck do you have?
96 with 320,000, Idm mod,
Tc mod, van turbo, 200/30 rosewood,
T 500 hpop, Dy 3" down pipe,
glowshift gauges, D60kp swap, custom track arms,
steering wheel swap, 6637 mod, Hydra chip, WW2,
calf fuel spring and BB mod
6.0 fan, cooler,
Pmf 2.25 rsk sd springs
78 f-150 turbo big block
old Smokey is offline
