CLUTCH - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 12-20-2009, 03:35 AM Thread Starter
CLUTCH
Ok I have a slight vibration in the floor of truck. It is there when truck is sitting idling or moving. If I push clutch in it goes away. I am thinking throwout bearing or I read something about clutch fork. What is the clutch fork and how do I check it? If the throwout bearing or clutch fork is going bad will it cause any problems?
99STROKINSMOKIN is offline
post #2 of 23 (permalink) Old 12-20-2009, 03:41 AM
Super Hauler!
Super_Hauler's Avatar
Re: CLUTCH
if its a clutch fork it could be broke or bent, only way to find out is to pull the tranny and take a look. If it the throw out bearing it could grenade like mine did. Either way you have to pull the tranny
Super_Hauler is offline
post #3 of 23 (permalink) Old 12-21-2009, 12:46 AM
Custom Trailer Sales
TrailerHauler's Avatar
Re: CLUTCH
I say throw out bearing, mines doing it lately to.
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #4 of 23 (permalink) Old 12-22-2009, 01:24 AM Thread Starter
Re: CLUTCH
Will it cause any problems if its the throw out bearing. I can hear a little bit of a noise if I listen close.
post #5 of 23 (permalink) Old 12-22-2009, 01:29 AM
Powerstrokin'
compresion ignition adict's Avatar
Re: CLUTCH
If its the throw out berring yes it will cause problems when it finally GOES. idk what year your truck is, but the older ones had a dual mass flywheel. And if the dual mass flywheel would hang up it would shake the truck and make a noise also.
'95 Powerstroke 250,
4'' Suspension lift
35" Tires
Traction bars
Gauges
FPR shim
Intake
5" Exhaust
Not Much Else
compresion ignition adict is offline
post #6 of 23 (permalink) Old 12-22-2009, 01:43 AM Thread Starter
Re: CLUTCH
Mine is a 99 and the clutch, flwheel and bearing is all only like 12,000 miles old. What will happen if its the throwout bearing?
post #7 of 23 (permalink) Old 12-22-2009, 02:45 AM
Early bird gets the worm
95dieselsmoke's Avatar
Re: CLUTCH
pull the inspection plate and have a look at the flywheel.
95 F250
Dana 60 swap
9" lift/40x13.5x20 ProComps
ZF5 swap/short throw/SouthBend CON OFE
Rosewood stage I's
TW live tuned
SD innercooler
AFE CAI
autometer pyro,boost
6" black miters
95dieselsmoke is offline
post #8 of 23 (permalink) Old 12-22-2009, 01:56 PM Thread Starter
Re: CLUTCH
It does shift completley fine and drive ok except for the little vibration. Does that rule anything out since it shifts great.
post #9 of 23 (permalink) Old 12-23-2009, 06:59 PM
Powerstrokin'
Re: CLUTCH
Pull your inspection plate. when my throw out berring went, I had lil pieces of it fall out when i took the inspection plate off. that will tell you quick.
4'' Suspension lift
35" Tires
Traction bars
Gauges
FPR shim
Intake
5" Exhaust
Not Much Else
post #10 of 23 (permalink) Old 12-23-2009, 10:29 PM Thread Starter
Re: CLUTCH
ok will try and pull the inspection plate. Is there anyway to check the clutch fork without dropping tranny?
