m/t into an auto? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 12-17-2009, 11:49 PM Thread Starter
StroKer01's Avatar
m/t into an auto?
Hey guys what all do / would I need to change my 6 speed into a auto??
TO MUCH FORD POWER!
2002 chevy Dmax PPE hot+2
1995 Power stroke .SD swap
Rangers lead the way
StroKer01 is offline
post #2 of 7 (permalink) Old 12-18-2009, 12:09 AM
Re: m/t into an auto?
i would start with an auto donor truck. that would make things go much better!!!!
USAF TSGT Retired "Medically"
99.5 CCSB 4x4 built motor and BTS
99.5 EX Cab Long bed with mild mods and BTS
Big thanks to Swamps Diesel and BTS!!!
randylamarr is offline
post #3 of 7 (permalink) Old 12-18-2009, 11:55 AM
The Fireman
big_stroker's Avatar
Donor truck would probably be the easiest way to go about it.
Or fine someone around you that wants to swap for a manual.
You will need a list of things
Flex plat
Adapter plat to go between the motor and transmission
A 4r100 tranny with transfer case
New steering column
Ether new wiring for the truck or a PCS controller, I would go with the PCS controller.
And im sure there are some other little things I'm missing.
big_stroker is offline
post #4 of 7 (permalink) Old 12-18-2009, 12:48 PM
brandon_oma#692's Avatar
Garage
come to the midwest and trade me trucks
brandon_oma#692 is offline
post #5 of 7 (permalink) Old 12-18-2009, 02:45 PM
Work in progress
opieg01's Avatar
SD is closer lol
2001 F-250 4X4 LARIAT Crew Cab,7.3, ZF6
GTX-4294r, Swamps 300/200%
couple other bolt ons
opieg01 is offline
post #6 of 7 (permalink) Old 12-18-2009, 03:13 PM
I get's it did!
SledYanker's Avatar
Flex plat
New steering column
Instrument cluster...
And, I second the PCS. It would be a considerably easier than fooling with the factory harness and YOU can set the tranny's shifting the way YOU want.
my .02
SledYanker is offline
post #7 of 7 (permalink) Old 12-18-2009, 06:52 PM Thread Starter
StroKer01's Avatar
yeah i just need/ want to do it to be faster and to no have to worry about shifting and watch the truck
TO MUCH FORD POWER!
