95 zf5 problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 02-04-2016, 08:52 PM Thread Starter
95 zf5 problems
Got a zf5 s42, I was driving the other week and I never had a second gear till this day it shifted in and when I shifted out the shifter and handle read second but tranny was stuck in second. Took top half off trsnny and put it in neutral. What's the deal? And a second issue I'm having is I have to hold the shifter in third or it will pop out and grind. What could be causing that? Thanks.
mbeaty95f250 is offline
post #2 of 2 (permalink) Old 02-20-2016, 11:25 PM
Hannibal
Re: 95 zf5 problems
Not an expert on transmissions, but, experiance says this is a shift fork issue. 2 of them in your case. 1-2 fork and 3-4 fork. Not that it matters. Either way it has to come out for repair. Up side... both going out at same time is a blessing. Change them all while your at it. Probable Cause, (I hope) previous owner was a gorilla and damaged it by forcing it to find the right gear. Otherwise its a weakness in that model.
Converting my MD5 to the zf due too similar issue and light/heavy duty concerns. 5-Reverse fork. no 5th and kickout on reverse.
Hannibals-Cafe is offline
