99 7.3 trans issue???? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 01-29-2016, 03:20 AM Thread Starter
burntorange's Avatar
i have a 99 f250 7.3 auto and i ordered a TS 6 position and put on it... after installing the programmer took it up the road... done well for 15 or so minutes... then took a shift like it went into neutral and went back into gear... then acted like it was slipping real bad and went to the rev limiter... took the programmer to stock and now it dont want to shift without letting out of the throttle and allowing it to shift... my computer code is NVK2 the programmer had NVK4 on it... is it a trans issue you programmer issue or something else? thanks for any imput
burntorange is offline
post #2 of 5 (permalink) Old 01-29-2016, 12:00 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 99 7.3 trans issue????
If it's back to stock and still doing it I think the trans broke.
Mark
Mark Kovalsky is offline
post #3 of 5 (permalink) Old 01-29-2016, 01:28 PM Thread Starter
trans or convertor?
post #4 of 5 (permalink) Old 01-30-2016, 12:13 PM
Yes, one of those two. Without tearing the trans down I can't tell you which one.
Mark
post #5 of 5 (permalink) Old 01-30-2016, 02:49 PM
s10mike's Avatar
the convertors in those trucks are known to be faulty. looks like either way that trans is coming out
s10mike is offline
