6.0 Trans cooler for $50. worth it? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 12-13-2009, 05:13 PM Thread Starter
peterbilt'in
Rob02F350's Avatar
hey
i sent a guy an email about some 6.0 parts, and hes willing to sell the cooler for 50 bucks because it has 205K miles on it.
still gona be a good cooler, just needing a flush done on it?
thanks
-Rob
2002 F350 extended cab XLT, 4x4 auto,194K mi @ 10/25/13, ELF7405, DP F5, ultra light gauges, all kinds of "improvements" Yukon Grizzly locker 6K helper springs, x code fronts. 2 Y2K jetta Tdi. RC2 tuned
Rob02F350 is offline
post #2 of 6 (permalink) Old 12-13-2009, 05:30 PM
theSLEEPER's Avatar
Re: 6.0 Trans cooler for $50. worth it?
Damn! Make sure it's not a scam! I bought mine from a douchebag that had all kinda brown sh!t in it and I had to flush it out real good. I blew some gas, then diesel, then transmission fluid through mine. It's been working great since I installed it! I love it!
theSLEEPER is offline
post #3 of 6 (permalink) Old 12-13-2009, 06:21 PM
You are taking a risk wrecking your trans, not worth it, I'd buy new.
1999 F350 6SPD 4x4 LARIAT Tymar, DP-F5, ITP Reg Return, 4" Exhaust **SOLD**
2002 F350 REG CAB DRW 2WD Tymar, PHP, 5" stack, DJM drop hangers and shackles, Hellwig sway bars, Nathan K5LA, Full Power '08 Mirrors...**SOLD**
DIRTBIKEZ is offline
post #4 of 6 (permalink) Old 12-13-2009, 06:34 PM
Fddriver2's Avatar
I disagree.
As long as it don't leak and you flush it "very" throughly I don't see a problem.
New is $300. It's not a moving part and it's behind the ac condenser. Should be a pretty safe buy, as long as you can trust the person you're getting it from....
Your Premiere Source for Ford Truck Parts and Accessories
I have a philosophy? Who knew. Ok, where's the beer?
In lockstep to the end of the world....
2002 F-250/CC/SB/4"SS Magnaflow/Evolution2/HPX/Pre pump mod/Harpoon/65psi fuel shim/FTVB/Zoodad mod/2008 Diff Cover/V-10 transmission cooler
Fddriver2 is offline
post #5 of 6 (permalink) Old 12-13-2009, 07:16 PM
Stroker67's Avatar
just flush it really really good!
Stroker67 is offline
post #6 of 6 (permalink) Old 12-13-2009, 11:56 PM
bad deal, tell me who has it and I will rough them up for trying to scam you...
2002 F250 CC 4x4
Tommy69Z28 is offline
