5r110 Trans Tenp Sending Location - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By Mark Kovalsky
  • 1 Post By metrojd
post #1 of 6 (permalink) Old 01-20-2016, 02:42 PM Thread Starter
2004 F350
Autoeter Trans Temp sending unit???
Test Port??
I pulled the Test Port Plug and it is shorter than the Sender..
Were To Put It???
Thanks
John
metrojd is offline
post #2 of 6 (permalink) Old 01-20-2016, 06:52 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 5r110 Trans Tenp Sending Location
The test port is the best place. The sender won't go all the way in, it's a tapered thread. It should fit there.
Zmann likes this.
Mark
Mark Kovalsky is offline
post #3 of 6 (permalink) Old 01-22-2016, 11:02 AM
I welded a pipe coupling in the pan and installed it there. Is that a good place?
dbshelton is offline
post #4 of 6 (permalink) Old 01-22-2016, 03:03 PM
In my opinion, no, it is not a good place. It is the coldest place in the transmission. There are also places in the pan where the fluid is stagnant, so when the trans heats up that's the last place to get warm.
Mark
post #5 of 6 (permalink) Old 01-22-2016, 04:29 PM Thread Starter
Smile Re: 5r110 Trans Tenp Sending Location
Thanks for the replies..
I used the test port..
Thanks
John
Zmann likes this.
metrojd is offline
post #6 of 6 (permalink) Old 02-01-2016, 11:09 AM
I was going to move it to the test port but the filter is in the way. Guess I'll do it at the next filter change.
