crap trans - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 12-11-2009, 06:19 AM Thread Starter
crap trans
So, I got the trans rebuilt but now its doing a sort of "two stage" shift into forth gear. A small decrease in rpm followed by the rest of the normal decrease in rpm when it finally goes all the way. Seems to do it less when its cold..
What do you think? Valve?
Also, I get a vibration that is not road related when there is a high load on trans. Steep hills, heavy loads and so on.
ELEV OFF is offline
post #2 of 7 (permalink) Old 12-11-2009, 03:44 PM
suprhlr's Avatar
Re: crap trans
the extra shift you are feeling is probably the TC lockup
2000 f-450 suprhlr LA West conversion
04.5 fummins CR, twins by Engineered Diesel,
Hamilton cams, Exergy 40% injectors, 48RE suncoast/ Goerend converter PCS controller, airdog 2, smarty, 4.10 gears, 39k miles
suprhlr is offline
post #3 of 7 (permalink) Old 12-11-2009, 04:47 PM Thread Starter
Re: crap trans
Ok, I can feel it lock up in 3rd but when it shifts to 4th will it unlock then lock again during the shift?
ELEV OFF is offline
post #4 of 7 (permalink) Old 12-11-2009, 06:50 PM
Re: crap trans
Depends on your programming. Push the OD off and when going fast enough turn it back on and see what the shift feels like. Probably still need someone to ride with you that is familiar or get a scan tool and watch gear status and lockup to see what is actually happening.
On edit: You may have some slippage or clutch chattering under load which could be indicative of pressure loss or other problems.
Tinscout is offline
post #5 of 7 (permalink) Old 12-12-2009, 05:36 AM Thread Starter
Re: crap trans
With the OD off I guess I could see how it locks up but it won't shift into 4th. That's what I am having problems with (3rd to 4th).
ELEV OFF is offline
post #6 of 7 (permalink) Old 12-12-2009, 06:42 AM
tbolt's Avatar
Re: crap trans
I think it's tc lockup. Mine feels that way.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #7 of 7 (permalink) Old 12-12-2009, 07:04 PM
What else?
smokyred's Avatar
Re: crap trans
Reread what he said.
Turn OD off, then when you get to the point it would normally shift into OD, turn OD back on so it can shift in. See what it feels like.
Dave
smokyred is offline
